Port ?s - Car Audio Classifieds!
Old 02-25-2010, 11:10 AM
peas247's Avatar
Loyal Member
0/11 sssss1001
Default Port ?s
trunk box forward firing, sealed off from the trunk. wana build a new box soon. possibly thrown around the idea of a center slot port. pro and cons of center port vs port on drivers side like ususal?
ca.com refs - dumple(x2), banginexplorer, r/t pimp(x2), select127, joey2714, rollerdj, lincolntc690, psychoacoustics, mk_, boltpride, SHiZNiLTi, emaxaudio, yunvme666, Coolwazabi, ssackett, JBGabriel, avs20, siddle, ddbump, mike465, andrizzle, SPY
Team Low Hurtz
Old 02-25-2010, 11:18 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Biggest issiue I usually run into with a center port design is more area displaced by the port for an equal sized port (more wood for 2 port walls since the ouside edge is not being used for one side of the port)
/ CAAA Member #2 /
Old 02-25-2010, 11:21 AM
peas247's Avatar
Loyal Member
0/11 sssss1001
gotcha. im just thrown around ideas
Team Low Hurtz
Old 02-25-2010, 11:22 AM
98AckCL23's Avatar
0/11 sssss9929
There was a build on Termpro with a center areo that was doing some big numbers (low 50s, IIRC) with a couple of DD 12s (?).
As for advantages vs the side ported box, I could see loading (if you're having issues like Rob) and maybe a bit of flow inside the car, but I'm not sure how much of an effect that would have, since it's a trunk. I could see flow inside the box being a bit better with the side port, since you're not going to have the overlapping waves that pass by the port.
If you give me some dimensions, I'll see what I can do about a 3-d modeling simulation using some CFD software tonight/tomorrow. Of course, that would all be theoretical, but might give you an idea...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Need help with port my63impala Enclosure Discussion & Design Construction Help 18 09-09-2009 12:29 PM
When the port isn't quite right... SomeGuyDude Enclosure Discussion & Design Construction Help 8 09-01-2009 11:50 AM
Port Gamble Car Show 2009 to Benefit Breast Cancer ~ Port Gamble WA ~ 08-29-2009 CACO's Car Show Bot Car Show Feeds 0 08-17-2009 02:00 AM
