wiring to this amp - Car Audio Classifieds!
Old 02-27-2010, 01:01 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
Default wiring to this amp
this is my friend's amp and the specs are
RMS Power (2 ohms)300 watts x 2 channels
and it's not 1 ohm stable
I know this sounds really dumb but I would need (2) D4 ohm subs right? and wire each one to 2 ohms to get the 300 to each?
wouldn't that make it a 1 ohm final load and it's not 1 ohm stable?
- CALI SOUNDS
- VERTEX AUDIO
Old 02-27-2010, 01:04 PM
hifonicsviii's Avatar
Loyal Member
0/11 sssss1423
well if the amp is 300 x 2 @ 2 ohms a dvc 4 ohm on each side or a dual 1 ohm on each side should give you what you want
the amp is 4 ohms mono, so you can wire them up to 4 ohms also if you like, 2 ohms minimum per channel, these class ab blow easlily if you drop below there specs
556 positive feedback from 506 users on Ebay!!!
Paypal verified ..207..since 2004
Bought from- - ShiZZZoN - pieper88 -
Sold to - super_duper - lilkman2202
Old 02-27-2010, 01:05 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
so if I get (2) D4 ohm subs, and wired each sub to 2 ohms, each on seperate terminals on the amp?
- CALI SOUNDS
- VERTEX AUDIO
Old 02-27-2010, 01:08 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
it's this amp
Nitro BMW-486 (bmw486) 2-Channel Amps Car Amplifiers Car Audio Car Audio, Video, & GPS Navigation - Sonic Electronix
- CALI SOUNDS
- VERTEX AUDIO
Old 02-27-2010, 01:10 PM
Loyal Member
0/11 sssss1423
so if I get (2) D4 ohm subs, and wired each sub to 2 ohms, each on separate terminals on the amp?
that would be perfect for this amp....2 ohms minimum like specs say on the website or 4 ohms bridged minimum
I have like 8 of these blown that I used for parts...Many people think they can wire it at 1 ohm
Old 02-27-2010, 01:11 PM
Loyal Member
0/11 sssss1423
RMS Power (4 ohms) 200 watts x 2 channels
RMS Power (2 ohms) 300 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 600 watts x 1 channel
Total RMS Power Output 600 watts
Peak Power Output N/A
Total Peak Power Output 2000 watts
Maximum Input Gauge Size 4
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 Ohms
Old 02-27-2010, 01:12 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
lol ok so wire each sub to 2 ohms, and each sub into seperate terminals on the amp? just wanna make sure that doesn't give it a final load of 1 and kill the amp
- CALI SOUNDS
- VERTEX AUDIO
Old 02-27-2010, 01:14 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Wire them to 2, or wire them to 2 then wire them in series to the amp bridged for a final 4 ohm load. I would do the latter so you receive a uniform amount of power to each sub.
My Car, My Ears.
Old 02-27-2010, 04:23 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
why? I can't use 2 D4 subs and wire each to 2 ohms?
- CALI SOUNDS
- VERTEX AUDIO
Old 02-28-2010, 02:25 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
You can, but IMO for subs a single circuit is better than 2.
My Car, My Ears.
wiring Jay Crawford General Car Audio Discussion & Questions 8 11-11-2009 08:21 AM
I need a little wiring help? FatBoy2 General Car Audio Discussion & Questions 15 10-28-2009 09:41 PM
Sub Wiring ??? Blackout General Car Audio Discussion & Questions 18 01-30-2009 06:59 PM
Sub Wiring Help dkhage1 General Car Audio Discussion & Questions 4 01-19-2009 09:22 PM
TV With All Wiring Blackout Car Audio Trader (WTT) 6 12-24-2008 01:02 AM
