First Wall - build it in car?? Need creative ideas - Car Audio Classifieds!
Old 02-27-2010, 03:07 PM
Vaginatarian's Avatar
0/11 ssssss473
Default First Wall - build it in car?? Need creative ideas
Im thinking of turning my suv into a 2 seater. I think I wanna wall 3 18" AQ HDC3 18's..
But Im in a pickle. Since I cant simply line 3 subs on the top or bottom as my car inside is only 54" wide door panel to door panel, I have to get a little creative with my front baffle, heres where I need ideas.
I can either build the box IN the car, and just make odd shaped pieces and such and get max ammount of volume
OR, I can build it outside the car which would b easier to fiberglass and brace and such but then Im limited to what I can fit thru the back hatch when installing it which is 37.5" width 30" height
Id need about 20-22 cubes for the subs anyways
To me the simplest way is to simply build the box inside the car (no idea how) box the baffle on the bottom and keep the top a rectangle port (possibly even interchangeable)
Id love any creative ideas though
Heres what I had in mind, basically a square cutout to mount the subs inside of, port ontop. Im thinking there must be a cooler, more efficient and possibly better way to mount the subs though. I couldnt think of anything off the top of my head, Im not sure if subs are even allowed to be placed or fired like that
Throw me ideas!! I wanna build!!
Old 02-27-2010, 05:52 PM
me neither
0/11 ssssss894
I actually think that one looks pretty good. Cool concept
Tim
Tim Strong
X-Box Live gamertag: quad drpr
"Once I have made a hasty, uninformed decision it cannot be changed." -Doofensmirtz
REFS:
SUBW123, splvictim20, ellocojorge, slamnride, Hellbound Train, Jstang2003, Basebalz13, CrownVic97, EpicenterDesigns, Extremechevyman67, spy, xseveredveganx
Old 02-27-2010, 05:57 PM
0/11 ssssss473
Well only other idea I could come up with was maybe angling the 2 outer subs so they werent firing right at eachother
Dont know whether to put the subs on the top or the bottom though... do I want the port shooting at my neck?? I was thinking of putting the port at the bottom subs ontop for a little wow affect, as my seats will cover most of the bottom of the box
Old 02-27-2010, 05:59 PM
0/11 ssssss473
But hell any other creative way Im down for
Im pretty sure Im gonna have to end up building it in the car almost completely though. Just make a floor and start building ontop of it I guess.
Probly will make 2 ports just to see what sounds better to the ear. Probly try 32 and 40hz
Old 02-27-2010, 06:41 PM
me neither
0/11 ssssss894
one thing I thought of was soing like a pyramid sorta like this O
do the port on the bottom or top. O O
You reckon you might have problems with cancellation with the two firing straight at each other.?? Or maybe take the design you have and mount the one on the left up high and the one on the right down low, or vice versa.
I dont know, im just trowin ideas out there.
Tim
Tim Strong
REFS:
Old 02-27-2010, 06:47 PM
SundownAudioNY's Avatar
Veteran Member
0/11 sssss4646
Feedback Score: 42 reviews
Why not do something like Michael Hughes 3 18's in his Yukon. Don't feel like looking for pictures but this will work just as good.
http://www.youtube.com/watch#playnex...&v=GQgmu7AuMjo
New York State Sales Rep
Team XS Power
PM Me For Termlab Testing
Old 02-27-2010, 07:05 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
i want the song played at 1:00 in that video.
Old 02-27-2010, 07:10 PM
0/11 ssssss473
Ya I pondered this design, not near enough port area though, I want 300+" of port so a rectangle port is most likely the best solution. With 3 9" areos in 20 cubes it just isnt enough to me
Old 02-27-2010, 07:15 PM
Veteran Member
0/11 sssss4646
Just an FYI, you don't need nearly as much port area with a aero port.
Team XS Power
Old 02-27-2010, 07:16 PM
Veteran Member
0/11 sssss4646
Phil Collins - In The Air Tonight
Team XS Power
Jacob's Wall Build Log sundownz (Sundown Audio) 114 07-12-2011 06:08 PM
92 s-10 ex. cab wall build s10 with 4 15's Build Logs 86 09-27-2010 03:11 PM
DDbump Wall Build ddbump Build Logs 79 09-09-2010 09:06 PM
xcort wall build tymoto21 Miscellaneous Build Logs 27 04-09-2010 03:28 AM
xcort wall build tymoto21 Uninterrupted Build Logs 5 03-31-2010 01:50 PM
