Will this amp work with an IDQ sub? - Car Audio Classifieds!
Old 02-27-2010, 04:22 PM
0/11 sssssss17
Default Will this amp work with an IDQ sub?
Will a eD nine.2x work with a Image Dynamics IDQ10V2 dual 4 ohm subwoofer?
AMP
RMS Power @ 12.5v : 2 x 200W @ 4 Ohm, 2 x 300W @ 2 Ohm
RMS Power (Bridged) @ 12.5v :1 x 600W @ 4 Ohm
SUB
  • Voice Coils: Dual 4 Ohm
  • RMS Power Handling: 250 Watts
  • Program Power Handling: 500 Watts
Old 02-27-2010, 06:53 PM
SundownAudioNY's Avatar
Veteran Member
0/11 sssss4646
Feedback Score: 42 reviews
IMHO, I would suggest a single channel class D. Whats your budget? You COULD run the amp bridged @ 8 ohms if you want to (~400rms).
New York State Sales Rep
Team XS Power
PM Me For Termlab Testing
Old 02-27-2010, 06:59 PM
Veteran Member
0/11 sssss4646
To answer question though, you COULD run the amp bridged @ 8 ohms (~400rms).
Team XS Power
Old 02-27-2010, 07:01 PM
0/11 sssssss17
How would I wire the amp to do 8 ohms? Will the sub be able to handle 8 ohms?
Old 02-27-2010, 07:08 PM
No, I'm not dead
0/11 sssss8128
Honestly, given that you are new to the hobby, I would just wire each coil to it's own amp channel and run it that way. Less chance to hook something up wrong.
Old 02-27-2010, 07:10 PM
Veteran Member
0/11 sssss4646
You wire the sub to 8 ohms, not the amp. Here is a wiring diagram and yes the amp will handle a 8 ohm load.
Team XS Power
Old 02-27-2010, 07:35 PM
0/11 sssssss17
Cool thanks!
Old 02-28-2010, 04:10 PM
0/11 sssssss17
Will just 1 IDQ10v2 be enough for the trunk of a sedan or should I consider the IDQ12? Not looking to have my mirrors shake, just want the low end hitting crisply but loud enough so I know it is there.
Old 02-28-2010, 04:32 PM
Rd4me's Avatar
0/11 sssss1231
Feedback Score: 32 reviews
for added bass and clarity a 10 would be fine but you will soon finding yoursellf saying man i wish it was louder. then you wind up like the rest of us lol. but go with your budget, and its always better to have to much than not enough
89 ef hatch,c&d tech batt in the back,4awg cadence wire,pioneer deh-4300ub,alpine mrp m1000,re audio hc 15",walmart pioneer's, daddy downsized system
team AudioMasochists founder
it's DD of course it will put up big numbers the d's on the cone add 10 db
Old 02-28-2010, 04:44 PM
0/11 sssssss17
If I were to get the 12 inch (same price) can it be tuned to function as if it were 10 in case I don't need the extra loudness? The reason I considered a 10 in the first place was because I wanted very tight and controlled sound.
I figure if I get the 12, I would build an enclosure around .75cu of air space. Or is that a bit too small? I just want to avoid getting a 12 and then it being far too loud and then wishing I got the 10. I listen to 95% rock
would this work JOSEPHKEMP General Car Audio Discussion & Questions 1 12-13-2009 10:24 AM
Would this work? tripleb45 General Car Audio Discussion & Questions 3 10-28-2009 11:59 AM
Would this set-up work? Bologna General Car Audio Discussion & Questions 95 04-30-2009 08:54 PM
First day at work. RidnClean Off Topic Chat 63 04-14-2009 07:46 PM
Would this work? korey_hofer Enclosure Discussion & Design Construction Help 19 03-26-2009 08:09 AM
