Whos got experience with Transpo 911 O2R Ext Reg? - Car Audio Classifieds!
Old 02-27-2010, 07:26 PM
thorshammer's Avatar
Loyal Member
0/11 sssss2315
Default Whos got experience with Transpo 911 O2R Ext Reg?
Alright Gents heres my problem.
I got a new 320amp alt and external reg. The regulator does turn on the alt but wont adjust it up nor down with the hardwired potentiameter. I pulled the pot from the circuit to test and it works both sides. Pot is 500 ohm and each side showed 564 wide open.
When I put it back in the system right side reads open and closed but left side reads 0 either direction. This leads me to believe its inside the unit that has the problem.
I originally wired it through a bosch 5 pin relay. Then tried direct ground,pos,field same result. I tried wiring direct to batt terminals up front the rear back bank etc... no change. It just wont adjust the voltage and this is a biiiiiiig problem as at idle its at 16.6v and you touch the gas and it shoots over 18v.
While this will be good for short bursts in the lane this is waaaaay too much for my cars computer etc...
Anyone with experience got any ideas?
Team DefJ
First Trunk in Iasca IDBL Bassboxing History to Average a 150+ after all 3 rds.
152.2 Legal Pr. of 10's out of a Trunk
153.1 Certified DbDrag Pr of 12's
Ported and Powered by Psychoacoustics
So whos got the biggest TV on CACO? Parker G Technology & Computer 94 03-06-2010 06:45 PM
AUDIOPIPE. Whos got the best price on a 3k? Vaginatarian General Car Audio Discussion & Questions 29 02-23-2010 05:46 AM
whos up? im bored snoopysnooper Off Topic Chat 74 12-18-2009 10:00 AM
Whos family member is this? jbizzle Uncensored Off Topic 28 12-10-2009 08:46 PM
