need help right now(amp protecting) - Car Audio Classifieds!
Old 03-01-2010, 09:25 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
Feedback Score: 22 reviews
Default need help right now(amp protecting)
so i just finished up my wall and was playing at low volumes to make sure everything was working good. voltage was above 14volts and volume was only at 2/3 power. my clif designs 4800.1lx went into protect. i turned the car off then back on and now it works. anyonw know why? and do you think it will do it again?
Current 09 BMW 335xi: SQ build with Sundown and IA in progress
Retired '99 Jimmy: Highest TL 155.1 w/ 2 self made 12s and AQ3500.1
Old 03-01-2010, 09:30 PM
Vaginatarian's Avatar
0/11 ssssss473
Check final ohm load
Check ground (resistance from amp - to final end - )
yes, it happened for a reason, dont use it as its currently wired
Old 03-01-2010, 09:33 PM
0/11 sssss6061
Maybe the voltage was too high.
Old 03-01-2010, 09:35 PM
Crescendo Audio's Avatar
0/11 ssssss669
Ground is your first culprit to check over.
Owner- Crescendo LLC
(941) 257-4767
Monday-Friday 9am-6pm EST
Email:
Optimal products, noble service, best value.
Old 03-01-2010, 09:38 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
I looked at the ground and power and they seemed okay. Final load is .5 ohm. Any other suggestions?
Old 03-01-2010, 10:01 PM
0/11 ssssss775
Feedback Score: 17 reviews
Maybe a short with one of your subs?
Old 03-01-2010, 10:56 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
so i drove around with it at half volume after checking and double checking my wiring and connections and no problems. i did notice that the back of the box, where the amp is mounted, still has some vibrations even after double baffling it. could this cause my amp to protect? im gonna put 2x4s on the back tomorrow and see if that will minimize the vibrations.
Old 03-01-2010, 11:00 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
damn ur sit. sucks bro. i noticed with my 4ch amp this was happening due to to high of input voltage through my rca's not sure if thats ur issue.....
SHABAM
Old 03-01-2010, 11:01 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
Or put a soft barrier between them, like foam tape...
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 03-01-2010, 11:03 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
im thinking of doing 2x4s and them some thick rubber stuff ive got at the shop. might work.
