amp queston - Car Audio Classifieds!
Old 04-10-2010, 10:34 PM
Mr.Green's Avatar
0/11 ssssss333
Default amp queston
Two questions what can cause fuse's to blow on amp and what is the best way to ground a amp?
Old 04-10-2010, 10:36 PM
TNJ
0/11 sssss7882
bad ground, sudden jolt from hitting something on the positive terminal, best way to ground is to the chassis.
Old 04-10-2010, 10:37 PM
Jh8909's Avatar
NJ Car Audio
0/11 sssss3219
Feedback Score: 38 reviews
or to a batt that is very close and grounded to the chassis along with a run to the batt upfront.
Pics too big in sig.. Please resize
Old 04-10-2010, 10:41 PM
Mr.Green's Avatar
0/11 ssssss333
yea because i just put in two sundown sae-1200d's and grounded them to the the floor of the truck sanded the area to bear metal and i have a D3400 under the hood along with a 150 alt upgrade and im haveing really bad voltage problems
Old 04-10-2010, 10:45 PM
TNJ
0/11 sssss7882
thank you.
you may need a bigger alt for those 2 amps. 150 just may not be enough current for them. but idk the amps personally.
Old 04-10-2010, 10:51 PM
Mr.Green's Avatar
0/11 ssssss333
yea there not suppose to be that bad on current from what i have herd but idk but i'll try relocating the grounds though and see if that helps cuz my kicker zx 250.2 have voltage drops as well when the other two amps are not running
Old 04-10-2010, 10:53 PM
TNJ
0/11 sssss7882
the kicker drops to? hmmm thats odd. how old are the batteries?
Mr.Green's Avatar
0/11 ssssss333
3 weeks old holds charge fine and everything but the grounds could just be not that great as well i mean there on the floor of the truck but its not very heavy metal though
Old 04-10-2010, 10:56 PM
TNJ
0/11 sssss7882
do you have the big 3 done? they say it helps voltage drop. maybe you need bigger batts? or bigger alt?
Old 04-10-2010, 10:57 PM
Mr.Green's Avatar
0/11 ssssss333
big 3 hole nine yards have consider getting a d3100 to put in the back along with the amps
