Box question... - Car Audio Classifieds!
Old 04-11-2010, 11:45 AM
0/11 ssssss271
Default Box question...
Okay im getting 2 hdc3 12' subs and im not too sure what the box needs to be...im new to car audio.
anyways would a box like this work? what size though?
and yes its in paint :P
Old 04-11-2010, 11:55 AM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
What are the things above the sub cutout
- CALI SOUNDS
- VERTEX AUDIO
Old 04-11-2010, 12:15 PM
0/11 ssssss271
"12'" lol sorry
Old 04-11-2010, 06:14 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Need more info.
What vehicle?
How much power?
Youtube VIDz :
Old 04-13-2010, 08:18 PM
0/11 ssssss271
mercedes benz 2008 e350
AQ2200D amp
Old 04-16-2010, 02:33 AM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
I would think a solid 4 cube box tuned to 38 would be about right for your setup. can you measure your trunk for space dimensions? and also the trunk opening so that we can figure out how big of a box will actually slide into the trunk.
Old 04-16-2010, 10:49 AM
0/11 sssss5305
with that power I'd do 4.5-5cubes.
what music you mostly listen to?
Old 04-16-2010, 03:08 PM
0/11 ssssss271
36 inches from side to side 16 inches tall 22 inches back
and rap
Old 04-16-2010, 04:26 PM
I'm F*CKIN Sexy!
0/11 sssss2132
with those dim's you will end up with a port displacement and maybe like 1 or 2 2x4's or so in there for bracing about 5 cubes give or take a little bit. now after sub disp maybe like 4.8 to 5 even. but with those dim. you should be pretty good. tuned around say like 38 htz or so with 2 4 inch areo's should be pretty sweet. You could do 6 inch areo's but really i'd say with two 4 inch areo's at 12 inches long would be 40 htz and that would be perfect for the 12's. had you gone with 15's maybe 38. But I think with the 12's going in a lux trunk you will want the higher tuning for a little extra power. and the subs will play pretty well into the mid 30's even at the 40 htz tuning.
Last edited by Highs On Bass; 04-16-2010 at 05:24 PM. Reason: I'm F*CKIN SEXY!!!!!!!!!!!!!!!!!!
Old 04-16-2010, 05:18 PM
I'm F*CKIN Sexy!
0/11 sssss2132
here's what I would do its a simple sketch up file with 2 4" areo's and 2 12's with a single 2x4 as a support
big 3 question. xxxbasshead General Car Audio Discussion & Questions 8 11-05-2009 07:53 PM
Box question??? BooKoo General Car Audio Discussion & Questions 0 09-08-2009 07:54 PM
Have question, Need help! Bigboiii General Car Audio Discussion & Questions 13 03-22-2009 08:52 PM
I've got a question... again madmat Announcements - Suggestions - Feedback - Support 6 03-20-2009 10:54 AM
H/U question? mcdstvn General Car Audio Discussion & Questions 4 03-17-2009 08:19 AM
