Orion hcca225 help - Car Audio Classifieds!
Old 04-11-2010, 02:45 PM
0/11 ssssssss5
Default Orion hcca225 help
I have a old orion hcca225 that pops fuses everytime I put a fuse in it. I have pulled the bottom and nothing looks burnt and nothing smells burnt. I am wondering if it is worth fixing, or if it is even a easy fix. Thanks for any help.
Old 04-12-2010, 08:16 AM
coefamily's Avatar
0/11 ssssss336
does it pop Immediatly after you supply power?
how about without the speaker hooked up?
Old 04-12-2010, 10:53 AM
0/11 ssssssss5
Pops as soon as you hook power to it. With the speakers connected it still does it.
Old 04-12-2010, 10:57 AM
0/11 ssss31257
it could be a bad power-input diode. {yeah, they can go bad}
Otherwise you could have a bad output transistor or two.
[if you upsize the fuse, you will blow the powersupply to high hell because of the short circuit] so whatever you do, don't do that.
Old 04-12-2010, 11:01 AM
0/11 ssssssss5
Yeah I did not want to upgrade the fuse just for that reason. I have had this amp for about 10 years and think I only used it for a few weeks. I jsut dug it out to find out it is doing this.
Old 04-12-2010, 11:03 AM
0/11 ssss31257
double check your power wires. but most likely, it's the diode.
Old 04-12-2010, 11:17 AM
0/11 ssssssss5
Hmmm. I wonder if that is going to be a cheap easy fix.
FS: Orion XTR 10" 4Ohm Subwoofer with Orion Box! Pillow 10" Subwoofers 5 03-07-2010 03:36 PM
WTB: Orion-dd-rd...more amcreynolds3 Wanting to Buy (WTB) 6 07-23-2009 07:22 PM
Orion THS T-150 worstenemy453 CACO Amp Internals 1 07-02-2009 05:22 PM
