Train Horns.... I need a compressor.. and some helpful ingenuity... - Car Audio Classifieds!
Old 04-12-2010, 03:39 AM
Vaginatarian's Avatar
0/11 ssssss473
Default Train Horns.... I need a compressor.. and some helpful ingenuity...
I basically wanna do a bidget train horn setup. Ive gathered 2 huge pieces, The horns, and the tank. Ive got 2 horns 30 and 36" both use 1/4" compression fittings. And I also have a propane tank for the air storage.
I plan on hooking this up to a manual swing valve of sort so I can swing this sucker open n closed and talk witht he horn lol
BUT I need a compressor. What compressor would you suggest?? I dont plan on using this horn ALOT, but having some fun with it would be nice, want something reliable.
Can anyone help me out on what I need and the best way to go about hooking it up??
Appreciate it
Ill post all pics nessecary lol
Old 04-12-2010, 04:00 AM
0/11 sssss2351
I'd get a viair compressor. Compressors | suicidedoors.com
4 15" Audiopulse Revos
2 SAZ3k's strapped @ 1 ohm
7 stinger Spv70 batts
1 Iraggi 300 amp alt
Old 04-12-2010, 04:02 AM
0/11 ssss31257
any compressor will do. {the compressor is just to keep the tank at pressure}
pull-chain valve from a semi would do what you need and they are cheap.
ebay;
12V HD COMPRESSOR For Horn On-Board Air System. Ebay.
$80 to $150 compressors for air horn, eBay Motors. Great deals on eBay!
Old 04-12-2010, 01:46 PM
0/11 ssssss473
Well these 2 compe with alot of things, relay and pressure switch, which Im sure are needed....
But they have a 150psi and a 120psi, theres quie a price difference...
Are these pumps good at all??
150 PSI 12V Compressor Train Horn Air Ride Suspension : eBay Motors (item 230461155003 end time Apr-18-10 19:38:02 PDT)
120 PSI 12V Compressor Train Horn Air Ride Suspension : eBay Motors (item 230459267409 end time Apr-14-10 09:30:08 PDT)
I dont quite get the wiring though.. or exactly how I would plumb the propane tank... I took the old valve right off the propane tanik so now its just like a 1" threadeded hole in the top of it
Old 04-12-2010, 01:58 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
if you have one at home and don't plan on using it very much. you can just put a quick connect fitting on it and just fill it up from time to time at home and don't have to worry about having a compressor in the car. if you do put on in there, i strongly suggest getting a pressure relife valve on there. i've seen twice were the compressor failed to stop doing some nasty damage to a car.
Proud Member of CAAA!
Old 04-12-2010, 02:59 PM
0/11 ssssss473
Ya I think I plan on using it more at one time than one fill would be good for no?? SO I think I would need a compressor. Like how many seconds could a propane tank seriously hold??
Cause I do already have a compressor at my house...
Old 04-12-2010, 03:01 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
i have mine wired to my horn switch on me steering wheel! hah! pluss the horn that i have i had my pop machine out a place for a 12v solenoid to screw into and act as the valve.
SHABAM
Old 04-12-2010, 03:04 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
that really depends on how many CFM they use. you could always try i out first that way, and if you don't feel like you can keep enough pressure in there to get you a couple of burst then you can allways go to a compressor in your ride. i forget the members name, but there was a guy on CA.com that was huge into train horns. just search for K5LA horns and you'll see him. if my next ride is big enough i'm going to get a K5 or K3 on there.
Old 04-12-2010, 03:06 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
lil something like this.
http://www.youtube.com/watch?v=UUNnC-9XMnI
Old 04-12-2010, 03:07 PM
0/11 ssss31257
Californians think their car horns are extensions of their mouths. {they use them a lot}
[I'm just sayin']
[Sold]athearn HO scale santa fe passenger train Nudels Miscellaneous Stuff For Sale 2 12-14-2009 11:38 PM
[Sold]Viair 400C Dual Compressor Kit duramaxxed Miscellaneous Stuff For Sale 12 10-27-2009 04:01 PM
[SOLD] F/S 12V Air compressor/horn kit loudwhat? Miscellaneous Stuff For Sale 0 07-10-2009 03:33 PM
Tips/helpful hint's to help to not your your setup JACKED splvictim20 Tutorials & Quick References 2 10-29-2008 01:05 AM
Man who wanted picture gets 'train rash' Patrick Simmons Off Topic Chat 3 09-17-2008 09:14 AM
