Noise in woofer - Car Audio Classifieds!
Old 04-12-2010, 06:24 AM
0/11 sssssss28
Default Noise in woofer
Hey guys, I'm getting a weird noise in my subwoofer. It's not the amp, I thought it was my old amp, but this one is doing it too. If I turn on anything that uses power in the car(headlights, heater, signal lights) you can here a feedback noise in the woofer. I don't understand what it could be. I have my power running up one side of the car, and the RCA jacks are on the other side. I have the R.E.M wire running up with the power wire.
Yesterday when I had it turned up good and loud (gain on only 11 o'clock) I smelled something and the red light come on in the amp, overload protection. And the main 60 amp fuse blowed inline of the power wire. I don't want to blow this amp, paid good money for it.
Any ideas
Old 04-12-2010, 06:28 AM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
sounds like a grounding issue
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Old 04-12-2010, 06:29 AM
TNJ
0/11 sssss7882
check your grounds. where do you have the amp grounded at?
TEAMLOWPOUNDERS
0/11 sssss3564
What amp? What size power wire? What voltage? And what's the preout on your head unit? And what kind of rcas?
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
AMP: 1 Sundown SAZ3000s
Old 04-12-2010, 07:10 AM
koopa's Avatar
0/11 sssss2800
the more info you give us the better we can help you whats your electrical like? but it does sound like bad grounds .
2008 tahoe
CDA9887 active
6 vifa tweets
2 10" Dayton mids
subs
tweets amp clarion 400.4
Mid amp autotek 400.4
Sub amp soundigital 12k
4 alts 1 stock 3 dc power alts
3 runs of shok wire
11 batts 1 deka and 10 shuriken
Old 04-12-2010, 08:49 AM
0/11 sssssss28
its a JBL GTO1201.1II I bought from Andrew on this forum. I have 4 gauge wire ran to the back from the battery, to my 3 ph capacitor. The ground is directly to the body of the car from the capacitor, then the capacitor goes to the amp. The RCA jacks are really thick good jacks. I don't know the brand of them, came in a kit. How would it be a bad ground, you mean not grounded good or loose? It's been there ever since I had the first amp installed and it was ok before, I never moved it or anything. I done some work to my HVAC controls (blue l.e.d's for buttons) and my fan don't shut off when I put it to off, just goes to low speed, wonder if that has anything to do with it.
Old 04-12-2010, 08:52 AM
koopa's Avatar
0/11 sssss2800
so the amp is grounded to the cap and than the cap to the body ?
2008 tahoe
CDA9887 active
6 vifa tweets
2 10" Dayton mids
subs
3 runs of shok wire
Old 04-12-2010, 08:54 AM
0/11 sssssss28
yeah, thats how I have it hooked up.
Old 04-12-2010, 08:55 AM
bikerdc17's Avatar
0/11 ssssss285
how is that it wouldnt work at all
bikerdc17's Avatar
0/11 ssssss285
imo
fan noise gbo559 General Car Audio Discussion & Questions 1 12-28-2009 01:52 PM
how to get rid of road noise maxkb20 General Car Audio Discussion & Questions 13 10-04-2009 10:57 PM
Speaker Noise mattinthebox General Car Audio Discussion & Questions 14 06-12-2009 05:51 AM
ground noise? caps General Car Audio Discussion & Questions 19 03-02-2009 07:10 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
