Active with 2- 4 channels? - Car Audio Classifieds!
Old 04-12-2010, 12:57 PM
0/11 sssss1642
Default Active with 2- 4 channels?
I want to redo my front stage, and I have 2 ppi pc4400.2 to work with as amps. I was wondering if I could bridge both amps and still go active. I was thinking of doing a set of selenium pro 8" mids, and a pair of the cresendo xst2 supertweeter. So would have 200 rms to work with on each driver. So can I do this?
Old 04-12-2010, 01:00 PM
0/11 sssss1642
actually I just saw that the seleniums and the tweeters were both single 8 ohm, so not sure how that would work also
Old 04-12-2010, 01:07 PM
98AckCL23's Avatar
0/11 sssss9929
Can you bridge the amps, and still go active? With that setup, yes.
Wire it up, and see how it sounds. PA gear should have a much higher sensitivity, which will help with the "lower" power. But you're running an amp bridged, which will give you more power per side...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 04-12-2010, 01:13 PM
0/11 sssss1642
ok, cool. I've tried active once, and failed. So I want to try again
how would I wire the drivers since they are single 8 ohm tho?
The amps do 50x4 @4 ohm, [email protected]@2 ohm, and [email protected] ohm bridged...
using my 880 for processing too btw
thanks
Old 04-12-2010, 01:25 PM
SundownAudioNY's Avatar
Veteran Member
0/11 sssss4646
Feedback Score: 42 reviews
Yes you can still run active. Only suggest I have is something that would play a little lower then the Selenium (assuming you mean the 8W4P).
New York State Sales Rep
Team XS Power
PM Me For Termlab Testing
Old 04-12-2010, 01:27 PM
Veteran Member
0/11 sssss4646
With PA drivers you don't need much power, most PA drivers will get insanely loud with little power. As little as 50-75rms on mids and 10-15rms on horns.
Team XS Power
Old 04-12-2010, 01:29 PM
Veteran Member
0/11 sssss4646
thanks
Each mid per channel on the first amp, bridged @ 8 ohms getting ~100rms. On the other amp you could run the tweeters off 2 of the 4 channels on the other amp getting ~25rms.
Team XS Power
Old 04-12-2010, 01:41 PM
0/11 sssss1642
I see what you are saying. Just wondering how much it will effect my tuning by bridging some. I though you are suppose to put tweets on the front channels, and mids on the rear.
and yes I was referring to the 8w4p, or how bout these Parts-Express.com:Eminence Alpha-6A 6" Midrange 8 Ohm | alpha 6a midrange open back 6" midrange pa midrange
thanks for the time and infor sudownaudiony
Old 04-12-2010, 01:43 PM
0/11 sssss1642
also I heard the cresendo super tweets like more power ?
Old 04-12-2010, 02:09 PM
0/11 sssss1258
when bridged, each speaker will have their own gain setting
FS: 4 BNIB Zed 4 channels mxer657 Multi-channel Amplifiers 24 06-29-2010 09:33 PM
Active? whitedragon551 General Car Audio Discussion & Questions 17 10-30-2009 09:51 AM
Bridging HU channels aturcotte127317 General Car Audio Discussion & Questions 4 09-01-2009 03:38 PM
Any BIG power 5 channels? BlackWaterOp General Car Audio Discussion & Questions 20 08-17-2009 11:31 PM
Why do mono blocks have two channels? BooKoo General Car Audio Discussion & Questions 20 08-17-2009 03:34 PM
