electrical question. - Car Audio Classifieds!
Old 04-12-2010, 03:23 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default electrical question.
I got a cadence ia-9 that i got @ 2 ohms and its supposed to put out 1400 watts i think. I dont think im getting the full power out of it and i was wondering if i got enought voltage going to it. I got a stock alt with a stock batt and a batt that has 1000 cold cranking amps and 150 capicity i think. Am i getting enought voltage? If not what do i need to get to get the voltage. help plzz
Old 04-12-2010, 03:24 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
go ahead and meter it. If you have a DMM put it on the battery when playing and see what your getting. If not, 1400 isnt a ton, maybe just a battery in the back would be fine. like there is a Batcap 2000 for sale here that would be great!
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 04-12-2010, 03:26 PM
0/11 sssss6030
dont have anything to check it with. wouldnt even know what to use to be honest with you
Old 04-12-2010, 03:29 PM
0/11 sssss3784
I don't know how into audio you are, but if so, a DMM, even a cheap one, is worth picking up. I'm not sure what else would check that.
empty trunk
DC Power 270xp
.... so far
Old 04-12-2010, 03:30 PM
0/11 sssss6030
So i do need an extra batt even with the two i got?
Old 04-12-2010, 03:31 PM
0/11 sssss3784
I'm not sure, a voltage check would be nice. All the wires hooked up right? You might be getting all you can out of it, maybe you just want a bigger amp
empty trunk
DC Power 270xp
.... so far
Old 04-12-2010, 03:33 PM
0/11 sssss6030
Dont need a bigger one. when i get the second sub itll put out 2500 watts i just want to make sure im getting all i can out of it @ 2 ohms. I got 4 guage wire run to it would it be better to have 0 guage ran insted.
Old 04-12-2010, 03:36 PM
0/11 ssss31257
Dry answer; 1400 watts takes 100 amps of current at 14 volts. {losses not accounted for}
if your alternator is good for 95 amps at 14.4 volts, you are still shy of the goal and you have nothin to run your car on. {headlights 40+amps, heater fan 25+ amps, other stuff 30+ amps, stereo itself 5+ amps = 100amps you need to run the car full bore}
do you have enough? nope. Will it survive? maybe.
all that doesn't account for the wires. {2 gauge or thicker will do}
Assuming you don't use the heater fan or the headlights and your amp make about 700watts rms, then with a 95 amp alternator you are good to go.
0/11 sssss3784
what are the inputs on it? 4 or 0? FYI^^hes better at this then I am
empty trunk
DC Power 270xp
.... so far
Old 04-12-2010, 03:40 PM
0/11 sssss6030
I think 0 guage will fit but idk. So i need a bigger alt and ill be good??
electrical question.... xjoeyc23x General Car Audio Discussion & Questions 7 02-22-2010 08:46 PM
another electrical question Memphistahoe02 General Car Audio Discussion & Questions 23 02-02-2010 08:36 PM
Another Electrical Question crownvicon26's General Car Audio Discussion & Questions 11 01-22-2010 11:55 AM
Another Electrical Question ClevelandFreeman General Car Audio Discussion & Questions 9 11-28-2009 04:24 PM
electrical question korey_hofer General Car Audio Discussion & Questions 10 02-04-2009 08:40 PM
