Thoughts about the RD 1750 - Car Audio Classifieds!
Old 04-14-2010, 11:40 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Default Thoughts about the RD 1750
Has anyone ever used one? Might be trading my AQ2200 for one so I can compete in Rookie1 division. Let me know your thoughts/experiences with them.
Old 04-14-2010, 11:55 AM
strpperpolef150's Avatar
Ladies love my pole
0/11 sssss3814
v.1 or v.2?
I have the 1750 v.2 and couldn't be happier with it. Puts out rated power and slightly more. Can be run at .5ohm daily safely. I beat on mine pretty damn hard and it's only gotten slightly warm.
It may have the name RD on it but its a tank of an amp. I wouldn't say it would be much of a downgrade from the AQ2200 and will allow you to compete in lower classes as it puts out like 400 rms @ 4ohm.
-Single cab F150-
HU: Kenwood KDC-X993
Processing: Clarion EQS746
Front stage: (2x) Shok CB 6.5
Comp amp: Crescendo 1000C4
Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
sub amp: (2) SAZ-2500s strapped @ 1
Electrical: Mike Singer 250a alt, D3100, (2) NSB90, 70+ft of shok
New numbers coming soon.....
I buy shifted motors
- Team PSI - Team Shok -
Louisiana/Mississippi Crescendo Rep
Old 04-14-2010, 12:51 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
So It'd be a good deal eh?
Old 04-14-2010, 12:58 PM
Ladies love my pole
0/11 sssss3814
which version are you trading for? What are the requirements for rookie 1?
-Single cab F150-
Old 04-14-2010, 12:59 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
Both version of that amp are good, don't let the RD name scare you lol.
- CALI SOUNDS
- VERTEX AUDIO
Old 04-14-2010, 01:04 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Not sure on which version. Rookie:
Section 5: Rookie Division
Intent of this class is to bring newcomers to local events and our sport. By developing these three Rookie classes it is our intent to give each and everyone new to this sport a chance of competing without being discouraged from getting beat by someone with much more equipment or a seasoned veteran with a lot of knowledge and experience under their belt. Everyone at events are encouraged to talk with all rookies to make them part of the TEAM NORTHEAST SPL family. Rookies are our future for further growth to make this sport continue for years to come so we ALL can play in the future.
  1. Nonmembers - First year “newbies” and vehicles only, as well as individuals that only attend a few local events a year. This can be decided by promoter and/or judges knowledge of competitor. Members - Anyone achieving 35 points or more in a single season within Team Northeast SPL in any prior season will no longer be considered a rookie.
    Anyone attending events within another organization in any prior season(s) and achieving 35 points or more in a season will not be considered a rookie.
  2. Competitors scores will consist of two 30 second runs. Score will be based on the total average reading of sound from the interior of the vehicle for the entire 30 seconds.
  3. Source of music must be selected from a commercially available album. The official Team Northeast SPL CD is to be used during all multi-point, record, and/or top scoring events. No straight test tones are allowed. Choice of track(s) shall play a full scale of music.
  4. Vehicles must be driven to event on their own power, and not towed to event.
  5. Vehicle must be able to drive into judging lane by its own power.
  6. Prefab boxes and custom built enclosures are allowed up to 3.0 cu' of internal airspace per subwoofer. A single rounded port up to four inches in diameter is allowed for each subwoofer. Slot ports are allowed in any size for each subwoofer.
  7. Windows must be able to move free of any obstruction from fully closed to fully open.
  8. Factory seats and seat belts must be in vehicle and fully operational.
  9. Any cutting of factory sheet metal or plastic paneling to gain more cab area is not permitted in the rookie classes. Examples of this are rear wall truck cut throughs, floor cut downs, side paneling in pickup trucks.
  10. Amplifiers adding up to 2000 watts RMS maximum. Ruling will be done by the manufacture highest RMS rating and/or CEA rating at 12.5 volts.
  11. Unlimited number of capacitors, but no more than a grand total of 5 Farads.
  12. Limit of one original equipment sized battery in the factory location. Battery may be upgraded but it must be the same size or smaller in every dimension as the stock battery. If the tray has been modified to fit the new battery then the competitor will need to be placed in a higher division, at minimum as a Woofer Cooker competitor.
  13. One auxiliary battery in the rear cargo area, no larger than 350 cubic inches in size (H x W X D). Example: Kinetik KHC1200
  14. Any battery upgrades in the Rookie division vehicles must be from a product line(s) that are available through standard retail channels for resale to the general public.
  15. Any battery in the vehicle will be considered as part of the charging system even if there are not any visible cables attached to them.
  16. Any non-sealed battery that gives off gases must be enclosed and vented to the outside of the vehicle for your own safety.
  17. All batteries must be securely fastened down.
  18. Voltage at amplifiers may not exceed 14.7 volts with vehicle running or shut off during a scoring run.
  19. Any competitor exceeding 140db while sitting inside vehicle must use protective ear protection. Any competitors exceeding a 150db will be asked to control their system from outside the vehicle, whether it is by remote or some other type of means to control the sound. Infared repeaters are available to allow addition range of wireless remotes. Once the car has registered a 150db reading at the event you will be asked to control the vehicle from the exterior on any additional runs. Any score of greater than 149.9db while inside vehicle for a second time at the same event will result in a score of a Zero. The intent of this rule is for your own safety. Headphones don’t protect your chest, heart and lungs!
  20. External stereo podiums are not allowed in any of the Rookie classes. Radio must remain in stock location or somewhere in the dashboard in a secure and safe location.
  21. Competitor may have up to ten persons holding vehicle during test runs, at least one foot of each person must remain on the ground during the entire testing runs.
  22. A total of only one person is allowed inside vehicle during testing run. Person must be properly seated in one of the front seats, or front bench seat.
  23. Sound deadening may be used throughout entire car up to inch thick per panel.
  24. Competitor shall be granted at least two runs per event. Three Additional runs may be granted by the promoter or host of event for a fee of $5 per extra run based on time, weather, and so forth.
  25. In pickup applications, speaker enclosures may not extend higher than the lowest point of the rear window glass in all truck applications. The enclosure itself along with any equipment attached to it may not be any taller than 25 inches total. Enclosure as well as any equipment attached to it must not extend forward of the rear wall more than 25 inches. Enclosure must be securely fastened for safety reasons.
  26. Enclosures and all other stereo related equipment in other type of vehicle other than pickup trucks may not be taller than 25 inches from the lowest point of the floor in the trunk and/or cargo area. Unlike pickup trucks, equipment can raise above the bottom edge of the rear window in SUV or hatch back type vehicles. This includes anything and everything attached to the enclosure. Examples of attachments are amplifiers, speakers, speaker wires, power wires, lighting, carpet, vinyl, suede, plastic, sound deadening, wire, sting ray, snake skin, ash trays, televisions, antennas, satellite dishes, GPS units, computers, alarm or remote start modules, coolers, refrigerator, freezers, laptops, trophies, felt, polyester, cotton, crossovers, equalizers, sound processors, speaker grills, power cells, batteries, caps, legs, props, amp racks, pens, pencils, markers, paper, gift cards, food, drinks, seats, floor buildups, 50/50 tickets, etc... All stereo equipment as well as power storage devices must remain within the cargo area or trunk. No stereo equipment or power storage devices may ever be forward of the "B" pillar at any time.
  27. Factory seals and gaskets must be in place in all doors, trunks, hatches, etc….
  28. Windows must be able to move free of any obstruction from fully closed to fully open.
  29. Nothing may interfere with the correct placement of the measuring device and its placement jig.
Rookie Classes:
• Rookie 1: 1-180 sq"
• Rookie 2: 180 - 280 sq"
• Rookie 3: 281 sq" +
Old 04-14-2010, 01:08 PM
Ladies love my pole
0/11 sssss3814
so instead of measuring rms at 4ohm they just use the amps highest rms rating @ 12.5v regardless? Technically your AQ2200 will probably put out less than 2k at 12.5v.
-Single cab F150-
Old 04-14-2010, 03:02 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
True that but I guess it depends on the judges.
Old 04-14-2010, 04:40 PM
Ladies love my pole
0/11 sssss3814
I'd ask more people about the class before making the trade.
Aside from any of that the amp is a great amp so you won't be disappointed in it.
-Single cab F150-
Old 04-14-2010, 05:42 PM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
i had the v.1 1750.1 and it was a very nice amp. i had it powering a RD H.W for a month b4 getting the hifonics cyclops.
WTB RD 3250.1 or RD 1750.1 V2 rsanch Wanting to Buy (WTB) 0 02-18-2010 09:02 PM
Wtb rd 1750.1 ckaiser1688 Wanting to Buy (WTB) 1 01-19-2010 10:31 PM
3250v2 to 1750 wiring help rumproast789 General Car Audio Discussion & Questions 26 01-08-2010 10:32 AM
[SOLD] Fs: Rd 1750.1 MysticStyl3z Mono Amplifiers 1 05-06-2009 10:44 PM
WTB: RD 1750.1 or IA20.1... wasted ink Wanting to Buy (WTB) 0 02-09-2009 09:43 PM
