never thought this could happen - Car Audio Classifieds!
Old 04-16-2010, 01:26 PM
kingmade08's Avatar
Awaiting Confirmation
0/11 sssss1067
Default never thought this could happen
i have a jbl gto 1201.1II
and ive been running a friends dual 1 ohm 15 off it in parralell for a few weeks now..so its at .5 ohms, the amp gets a lil hotter than it used to but its making a lot more power...supposedly this amp isnt stable under 2 ohms...my imp rise is to 1.4 something but still. how is this possible?
TEAM SUNDOWN AUDIO
Old 04-16-2010, 01:29 PM
Prohibited Sellers/Buyers
0/11 sssss6709
Feedback Score: 17 reviews
idk but unless you got the electrical to back it up don't test it or youll see the magic smoke.
Old 04-16-2010, 01:37 PM
kingmade08's Avatar
0/11 sssss1067
ive been runnin it like that for a few weeks, 145 amp alt,big three and an agm batt up front,doesnt drop under 13.6
TEAM SUNDOWN AUDIO
Old 04-16-2010, 01:38 PM
strpperpolef150's Avatar
Ladies love my pole
0/11 sssss3814
With a rise almost to 2ohm and a good electrical I can see it working out.
-Single cab F150-
HU: Kenwood KDC-X993
Processing: Clarion EQS746
Front stage: (2x) Shok CB 6.5
Comp amp: Crescendo 1000C4
Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
sub amp: (2) SAZ-2500s strapped @ 1
Electrical: Mike Singer 250a alt, D3100, (2) NSB90, 70+ft of shok
New numbers coming soon.....
I buy shifted motors
- Team PSI - Team Shok -
Louisiana/Mississippi Crescendo Rep
Old 04-16-2010, 01:44 PM
0/11 ssssss657
I would reconsider this. you never know whats gonna happen.
had a buddy install 2 12s on a mtx 81000d at 1 ohm. he didnt know it was a 2 ohm stable amp. I told him and before the kid could get back to the shop with it, it was toast. I highly doubt his .5 rises near 2 ohms IMO
Old 04-16-2010, 01:52 PM
0/11 ssss31257
It's fine. Run it.
your amplifier is rated for what it can do with a moderate power supply without blowing up. The engineers probably have a 50-75% safety on it so silly people don't blow them to high hell. {they say 2ohm stable but it may really be .75ohm stable in your application}
Cooling it some might give you peace of mind but if you've run it for two weeks already, it's not going to die.
The down side is the loss in clarity and damping factor {signal control} but if it sounds good, as I said before, just run it.
Also, if you set it so it doesn't clip, everything should live a very long time.
Old 04-16-2010, 02:07 PM
bwoodroof's Avatar
Brandon W.
0/11 sssss1648
You might want to rethink this statement.
2008 - MECA Radical X2 World Champion 150.2
2009 - MECA Tennessee Radical X2 State Champion 153.2
2010 - MECA Radical X2 2nd Place 159.9
Shocker Sigs FTW!!!
Team Bangin' on a Budget
Old 04-16-2010, 02:17 PM
0/11 ssssss436
Minimum rise i normally see is 3x what the dcr/minimum wired load is. I've seen 1 ohm loads go up to 6 ohms, theres a lot of variables there. Expect a .5 actual load to be at least a 1.5 ohm load, most likely even higher. I'm not one of the people to go into detail though, i just retain what i've learned here, i'm sure one of the guys who i've learned from will chime in when they read the thread.
I have seen a few that looks like an entire football game was played on top of the amp by 1000s of little midgets with sharp cleats on, though... makes me wonder what the rest of the install was like. But... those are set aside as "C" stock as Chris stated.
I forgot that you were a fetus, Eric
why does this always happen to me :( korey_hofer Enclosure Discussion & Design Construction Help 8 03-03-2010 11:33 PM
Why would this happen? twistedchild420 General Car Audio Discussion & Questions 8 02-20-2010 11:25 AM
why does this happen? BASSLOGHEAD General Car Audio Discussion & Questions 11 12-05-2009 08:42 PM
What will happen Cal1089 General Car Audio Discussion & Questions 9 09-05-2009 10:36 AM
this ever happen to anyone else bones22 General Car Audio Discussion & Questions 4 04-11-2009 12:24 PM
