Amp wiring issue :/ - Car Audio Classifieds!
Old 04-16-2010, 10:06 PM
D'90's's Avatar
0/11 sssssss51
Default Amp wiring issue :/
I only have an issue going on with my wiring to my amp. I have done hours of trouble shooting and haven't found the problem as to why my amp isn't getting any power. I decided I wanted to move my sub out of my suv for a moment and totally forgot that I left the amp's ground, power and remote start wire alone. I wasn't paying attention and bumped the ground and power wires together and it caused a spark. I was extremely worried and checked my fuses and wiring. Nothing had been blown or burned so I reconnected my wiring to my amp and sub. As I turned my suv on everything worked fine but the amp didn't turn on. I tried everything. From replacing the remote wire to even splicing a 14 gauge wire to the power and the remote start but obviously this takes current from the head unit to the amp which barely gives it any power to turn it on. After testing and testing I finally tested the power wire and have found there is the current drawing from it. I checked it's fuse and it didn't blow. So my question is should I replace my power wire or is there something else I have missed? I'm not sure if this is the correct place to post this subject matter but regardless I hope someone here can help. Thanks
D'90's/Nidez
Old 04-16-2010, 10:10 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
That wasn't confusing at all.
Do you have 12V on your power wire?
Is your ground secure?
Do you have 12V on your remote wire?
When you hook up only the power and ground wire and you jump the + to the remote terminals does it turn on?
Team CACO Team SHOK
Supporting Member
Old 04-16-2010, 10:41 PM
D'90's's Avatar
0/11 sssssss51
Yes I have 12v on my power and remote wires and the ground is properly fastened. I'm slightly lost about putting + to the remote terminals so if you could explain that more to me I can possibly answer that.
Old 04-16-2010, 10:48 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Crap I have videos showing how to test your amp on youtube but I can't get on there at work to link you.
Search for a video named "How to troubleshoot your amp" by ChevelleSS on youtube.
Heck if you can find any videos by ChevelleSS you can find the videos in my channel.
Team CACO Team SHOK
Supporting Member
Old 04-16-2010, 10:49 PM
hifonicsviii's Avatar
Loyal Member
0/11 sssss1423
Make sure your fuse is good, Simply by looking at it won't help...
I've personally seen a few fuses go bad that simply let enough current to pass to read 12v with out a load....Most of these fuses are the AGU glass type....If you have a volt meter check it for continuity or simply replace it....
If you volt meter or light tester turns on by simply touching the power wire to tip of tested and ground to other lead of tester....Then you have power...
YOu can touch a wire from postive cable to remote terminal....If amp turns on then you have a bad signal wire coming from deck
556 positive feedback from 506 users on Ebay!!!
Paypal verified ..207..since 2004
Bought from- - ShiZZZoN - pieper88 -
Sold to - super_duper - lilkman2202
Old 04-16-2010, 10:50 PM
Loyal Member
0/11 sssss1423
Got them for you...
http://www.youtube.com/watch?v=VoHHh9kFjpM
http://www.youtube.com/watch?v=BNi6dMdvHbg
Old 04-16-2010, 10:52 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Are those my videos? (MTX Thunder 302 laying in a blue driver seat?)
Team CACO Team SHOK
Supporting Member
Old 04-16-2010, 10:54 PM
Loyal Member
0/11 sssss1423
I guess...Are they lol
Old 04-17-2010, 12:33 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I don't know. I'm at work and youtube is blocked so I cant see them. I just see the embedded video box, but not title or picture or anything.
Team CACO Team SHOK
Supporting Member
Old 04-17-2010, 11:12 AM
D'90's's Avatar
0/11 sssssss51
Thanks, I'll check the videos sometime soon when I can get on a bigger screen. (Using my BlackBerry) well so far everything appears to work except the power wire. The fuse appears to work and sends current as fine as a new fuse would so if it isn't at the beginning of the power wire that is wrong then there must be something wrong with the rest of the power wire, no? What exactly happened when the ground and the power wire touched?
Issue with my new amp. JLAudioCavalier General Car Audio Discussion & Questions 3 04-14-2010 06:31 PM
Amp issue? audiobahnfan General Car Audio Discussion & Questions 0 04-08-2010 02:07 PM
Another Issue newarkbeast973 General Car Audio Discussion & Questions 9 08-01-2009 11:21 PM
Amp issue NoPh33rRaCiNg General Car Audio Discussion & Questions 12 03-13-2009 09:36 AM
Alt issue help bumpin buick General Car Audio Discussion & Questions 6 08-02-2008 10:03 PM
