Corner Loading in A Trunk - Car Audio Classifieds!
Old 04-19-2010, 01:45 PM
ascitiesburn69's Avatar
0/11 sssss1645
Default Corner Loading in A Trunk
Anyone ever done it with good results? I heard a car the other day with 4 dd 8"s in a corner loading box in a trunk and it was seriously low and loud. Like back door flexxing crazy low. In case you don't know what I mean by corner loading....Basically the box sits as far back to the rear as possible with a sub(or two) firing into each the driver's side and the passenger side and the port is firing back. Will more than likely try this out with my new setup with 2 10"s and see what happens. But I want to know if anyone has done it successfully and maybe give me some tips.
Team S.P.E.A.D.
Trunks FTW
Old 04-19-2010, 09:17 PM
0/11 sssss1645
bump...someone has to have done this before.
Team S.P.E.A.D.
Trunks FTW
Old 04-19-2010, 09:18 PM
I doubt anyone on here has anything small enough to corner load, it just makes it act like a bandpass box by doing it though
Old 04-19-2010, 09:19 PM
0/11 sssss1645
Really? I never really heard that before.
Team S.P.E.A.D.
Trunks FTW
Old 04-20-2010, 08:28 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
It helps to create more resonance which can give the illusion of more output, some do work well though. The Infinity Basslink works off this methodology.
My Car, My Ears.
Old 04-20-2010, 08:33 AM
0/11 sssss1645
I see. I'll prob try it out just to see what happens. I also have see a guy do 2 tens firing to the drivers side and 2 10s firing to the pass side and port back in a trunk do a 52.8 outlaw.
Team S.P.E.A.D.
Trunks FTW
Old 04-20-2010, 08:47 AM
SundownAudioNY's Avatar
Veteran Member
0/11 sssss4646
Feedback Score: 42 reviews
The DD 1008a and 1508 have control issues on high power. Alot of people running over 700rms to a 1008a or 1508 use a load wall to help with loading. My new enclosure for my SA-8 in my Silverado is side firing with a loading wall to help with power handling.
New York State Sales Rep
Team XS Power
PM Me For Termlab Testing
Old 05-13-2010, 01:40 AM
0/11 sssssss38
With my setups, I always tried to keep the subwoofers all on the same plane. Helps keep the phase in line. Maybe try the subs in one corner with the ports in the other corner?
COMPETITION CORNER - Put your scores, pics and vids here using SD muriloalvares General Car Audio Discussion & Questions 35 04-25-2011 12:19 AM
FS: Trailblazer Clear corner headlights Andrew Miscellaneous Stuff For Sale 2 03-11-2010 08:36 PM
Front Loading Horn vs 4th order MisterGrubbs Enclosure Discussion & Design Construction Help 38 09-25-2009 01:58 AM
rear-loading folded horn box build SPY Off Topic Chat 22 10-08-2008 08:21 PM
How to make a kerfed port / corner SPY Tutorials & Quick References 4 09-19-2008 10:11 PM
