1994 ford aspire alternator - Car Audio Classifieds!
Old 04-20-2010, 04:47 PM
0/11 ssssss400
Default 1994 ford aspire alternator
Do You make a 300 amp alt for this car? Or what is the biggest amperage and what is the cost.
thanks, josh
Old 04-20-2010, 05:21 PM
MECHMAN's Avatar
0/11 sssss1142
Your Aspire only has a 4 rib belt to turn the alternator, which means anything over about 175 amps is going to slip like crazy. We have a 220 amp bolt in large case conversion kit for $449, but you are going to have to run the belt really tight, and it will probably still slip some at full load.
Old 04-20-2010, 06:24 PM
0/11 ssssss400
Well that's sucks to hear. Do you have a 175 or only the 220? I will just do a massive battery bank.
Old 04-21-2010, 09:02 AM
MECHMAN's Avatar
0/11 sssss1142
We have a 150 for $375. The cool thing about the 150 is that it has so much cooling for it's output, it's almost indestructible. It also has full output at only 1,000 rpm engine speed.
MECHMAN's Avatar
0/11 sssss1142
If you took the AC compressor off, we could fab up a custom unit to bolt in place of it so you could run twin 150's.
Old 04-23-2010, 07:24 AM
0/11 ssssss400
That is a very good idea. That would work for me.
Old 04-23-2010, 08:08 AM
MECHMAN's Avatar
0/11 sssss1142
Well you would need to take some clearly focused pictures of the AC unit mounted on the vehicle, and then you would need to send us the AC compressor for measurement. We normally charge $400 - $500 for a custom housing/bracket/harness kit depending on how complicated the kit needs to be.
WTB 250-350+ Amp Alternator for a 2000 5.4L Ford F-250 Josh Wahlie Wanting to Buy (WTB) 4 02-02-2010 09:55 AM
5.0 Ford Mustang 200 amp Black Powermaster alternator MECHMAN Wiring, Electrical & Other Installation Equipment 3 06-22-2009 11:48 AM
