Where in my sub should I mount my digital thermometer - Car Audio Classifieds!
Old 04-20-2010, 05:07 PM
Prohibited Sellers/Buyers
0/11 ssssss481
Default Where in my sub should I mount my digital thermometer
I have a few of these and I am rebuilding my power hx2 10's.
http://cgi.ebay.com/Digital-LED-Ther...item563b77f846
They have a huge pole vent, a very very vented basket, and no former vents on the coil. So with this style of cooling where would be the best place to mount the small probe in each sub to get a temp closest to coil temp.
Heres a 15" motor and basket I havent uploaded my pics yet but notice the screens on the basket - basically the same as my 10"ers.
In the pole from the back all the way up at the top of it?
On the basket right next to the coil near the motor bolts/ almost in the gap.
Or somehow risk mounting them to the former on the inside away from where it would hit the pole at full excursion.
The object is to monitor coil temperature from my dash next to the volt meter.
Thanks. THe probe is about 1/8th inch around and 3/4 inches long with two wires coming out of it. Stainless steel i think or aluminum.
I figure I can just monitor the gauge and then check dustcap temperature accordingly. I usually never try to let the dustcaps get warm on my subs Ive found that not long after that they start to stink.
Old 04-20-2010, 05:11 PM
indytrucks's Avatar
CACO Late Night Crew
0/11 sssss5387
That may just be the most unnecessary thing I have ever seen. Does it actually have to make contact to get a reading?
Old 04-20-2010, 05:16 PM
0/11 ssssss786
LOL x2. The only way you can see the temp. is if the subs are inverted or your box is plexi right?
Old 04-20-2010, 05:24 PM
0/11 sssss1917
You fail at reading.
The OP said "the object is to monitor the coil temperature from my dash next to the volt meter."
Old 04-20-2010, 05:31 PM
0/11 ssssss786
Yeah i just looked at pics.
Old 04-20-2010, 05:34 PM
Jh8909's Avatar
NJ Car Audio
0/11 sssss3219
Feedback Score: 38 reviews
then fail.
Pics too big in sig.. Please resize
Old 04-20-2010, 05:35 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
most thermal couplers like this need direct contact with what they are reading. with that being said, you would have to attach it direcly to the VC's or the former. of course, that cant be done, so if you are dead set on doing this, your going to have to go about a different way.
Proud Member of CAAA!
Old 04-20-2010, 05:37 PM
0/11 ssssss786
Dont clip and no worries
Old 04-20-2010, 05:42 PM
ascitiesburn69's Avatar
0/11 sssss1645
X2 on being useless...Do you know what your Voice coil is supposed to be at temperature wise? Didn't think so, so therefore you'll never know if your at a "good" reading or not....as previously stated "Don't clip" and don't play below tuning too much and you will never have a prob....
Team S.P.E.A.D.
Trunks FTW
Old 04-20-2010, 05:43 PM
0/11 ssss31255
You could try it in the vent. [gorilla tape it there]
Maybe drill it into the Motor? j/k
The idea is nice enough but truly the voice coil temperature would be best assumed from the motor magnet temp somewhere which is not well ventilated. The problem is; Power HX2 coils are vented better than most subs and you'll probably never really know the voice coil temperature. {even after you kill it again}
Flush mount ? on1wheel01 Enclosure Discussion & Design Construction Help 9 03-08-2010 05:59 PM
Shallow mount? Minitrucker (PSI Car Audio) 21 02-26-2010 02:59 PM
WTB: 4 Pin XLR Panel Mount (14) RollerDJ Miscellaneous Stuff For Sale 0 09-16-2009 09:54 PM
WTB Something to mount these in/on mytyeerinpie Miscellaneous Stuff For Sale 5 02-20-2009 05:13 AM
Digital battery terminal, digital mini anl fuseblock and RCA's SPL Guru Wiring, Electrical & Other Installation Equipment 3 09-05-2008 02:14 PM
