MB Quart DSC2000.1 wont cut on! - Car Audio Classifieds!
Old 04-20-2010, 05:57 PM
mads10bass's Avatar
NOT LOUDER THAN YOU :(
0/11 sssss7335
Feedback Score: 36 reviews
Default MB Quart DSC2000.1 wont cut on!
Ok guys I installed the MB Quart today. I have an eclipse cd3100, all knu koncepts 1/0, a C&D 100 ah battery, Knu rcas, 2 soundstream t4 10s wired to 1 ohm, and an mb quart dsc2000.1. The amp came on when I first put it in but now it wont come on. I checked all the fuses and checked the voltage. All seems to be fine but it wont turn on? What kind of voltage do I need for the remote wire? It reads 3millavolts?
WOW
Old 04-20-2010, 05:59 PM
Undadog's Avatar
0/11 ssssss810
have you double checked your ground wires
Obsidian Car Audio addict
0/11 ssss31255
you need 12 volts on the remote lead.
try running a jumper from the power to the remote terminal. if it turns on, look at your deck.
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
umm, you need 12vdc... lawl, sounds like you got a loose connection somewere.
Proud Member of CAAA!
Old 04-20-2010, 06:04 PM
mads10bass's Avatar
0/11 sssss7335
fweew thank you guys ill check it out in the morning the gf went off with her car. Ill try the jumper thing out and if it turns on ill run another remote wire to the back. The car runs at 14.5v so its not the grounds.
WOW
Old 04-20-2010, 07:45 PM
Vaginatarian's Avatar
0/11 ssssss473
If you dont have 10+volts at the remote wire connection then thats obviously your problem
Old 04-20-2010, 07:47 PM
mads10bass's Avatar
0/11 sssss7335
I used the remote wire that is attached to the rcas. maybe that is the issue ill go to wallyworld and pick up some wire and use that.
WOW
Old 04-20-2010, 11:04 PM
0/11 ssssss473
If it worked before, Im gonna guess your connection came loose
Old 04-20-2010, 11:07 PM
Loyal Member
0/11 sssss1129
those RCA remote wires are ****ing usless, run a new one with 16g wire then try again.
2012 West Coast INAC Amateur SQ 1st place Champion!
2012 National 2nd place INAC Amateur SQ Champion!
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
sucks dude. just wire a relay with the remote wire right off the batt. problem solved
SHABAM
Best deal on MB Quart DSC2000.1 orangelss General Car Audio Discussion & Questions 7 08-27-2010 10:39 PM
[SOLD] MB Quart DSC2000.1 Undadog Mono Amplifiers 10 04-19-2010 09:56 PM
[TRADED]MB Quart DSC2000.1D LIKE NEW toaster Mono Amplifiers 13 04-03-2010 12:07 AM
WTT MB Quart DSC2000.1D Mono Sub Amp TickTock Car Audio Trader (WTT) 7 03-28-2010 10:02 PM
MB Quart DSC2000.1 Strapable? SPY General Car Audio Discussion & Questions 7 01-03-2010 01:58 PM
