3sixty.1 to OEM amp? - Car Audio Classifieds!
Old 04-21-2010, 02:23 AM
0/11 ssssss624
Default 3sixty.1 to OEM amp?
Do you guys think this is doable? I want to add a 3sixty.1 to the Mini but I want to run the stock deck to the 3sixty.1 then out to the stock amp as well as to my sub amp. I have a specific point to tap the stock harness and feed the stock amp. The reason I want to do this is just give the stock amp a little more input as at full volume it is pretty (really)low. The stock deck will not clip at full volume so I know it has a clean signal. I also like the idea of a better EQ as the stock deck only has bass and treble adjustments. Would the 3sixty.2 be better for this?
By the way, this is in my 2009 Mini Cooper with the hifi upgrade (10 speakers) and all speakers upgraded to Mb Quart highs and mids.
Tell me what you all think!
Thanks all!
Old 04-21-2010, 11:41 AM
0/11 ssssss624
Anyone?
Old 04-28-2010, 08:57 AM
0/11 ssssss624
Ne1?
Old 04-28-2010, 09:03 AM
0/11 ssss31255
The 360 does not have speaker level outputs.
A JL Audio "Clean Sweep" is made for this. {it cleans up and adjusts speaker level signal}
Old 04-28-2010, 09:15 AM
loud-n-low's Avatar
0/11 ssssss695
agreed. i loved my clean sweep in my Acura
Old 04-28-2010, 09:45 AM
0/11 sssssss17
I don't see the point in doing this, but I guess it is doable as long as the OEM processing happens in the deck and not in the amp and you have a way to interface the 3sixty with factory amp..
Old 04-28-2010, 09:55 AM
0/11 ssss31255
Because the 360 doesn't have speaker level outputs, it can't be used that way.
The JL Clean Sweep is designed to clean up any "factory processing errors" [it has magic built in]
Old 04-28-2010, 10:17 AM
0/11 sssssss17
Please read everything I write. He can still accomplish this, just not through native means.
I do believe I let it known it was doable under set conditions. I am fairly well versed in the 3sixty equipment and know this information already.
The 3sixty also cleans up OEM processing errors as well. It just doesn't have speaker level outputs.
In any event I see no reason at all to do what he wants. A small amp for the mids/highs can be added cheaply and with better results.
Old 04-28-2010, 02:24 PM
0/11 ssssss624
If I take the stock amp out of the system it will throw errors to the car control computer. I want to run this from the deck signal level outputs to the amps signal input. I should only need to sodier rca inputs to the stock amp inputs (or not)
So will it work this way?
WTB: Rockford Fosgate 3SIXTY.2 Rose-Villian Wanting to Buy (WTB) 2 04-14-2010 03:15 PM
WTB Rockford Fosgate 3sixty.2 rjcastr Wanting to Buy (WTB) 0 12-28-2009 08:36 PM
WTB: Rockford 3sixty.2 vactor Wanting to Buy (WTB) 0 08-19-2009 06:56 PM
NIB 3Sixty.2 norcalsfinest Head Units, Processors & EQs 0 11-13-2008 12:05 AM
