big 3 question - Car Audio Classifieds!
Old 12-06-2008, 09:28 PM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
Default big 3 question
I just did the big 3 on my truck and was wondering if i could benifit any from running a ground from my alternator to my battery? the alt has just 1 post on it for pos. id assume youd ground it from a mounting bolt.. but which one?
Just kinda wondering..also if this is benificial...how? what does it to add to the mix
Old 12-06-2008, 10:59 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Any mounting bolt that is accessable, and I would say it's not needed because you have the factory 4AWG batt to motor.
Old 12-06-2008, 11:04 PM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
which is now 1/0
Old 12-06-2008, 11:11 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Yeah so it should be good. The factory location is on the intake correct? I don't know if they changed it in 3 years or not, but still being TBI it should be the same.
Old 12-06-2008, 11:12 PM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
ya it was on the intake.
also sanded down the body ground pretty good..
Old 12-06-2008, 11:25 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I didn't do a body ground, I just left the factory batt to motor, put in a batt to frame, bat to alt power, and alt to frame.
Old 12-06-2008, 11:33 PM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
i thought about getting ip_phreak to weld me a threaded rod to my frame.. but havent had time to care..i dont think theres a factory bolt anywhere...idk maybe a mounting bolt only done a quick look..nutin seriously in detail
Old 12-07-2008, 12:10 AM
bwoodroof's Avatar
Brandon W.
0/11 sssss1648
I would put as many grounds as I could afford on my car, Especially the alternator to battery. Current travels faster through copper than steel. I even ran 4 runs of 1/0 Ground with my 4 Runs of 1/0 Power wire and gained around .3V in my setup. To me thats a ton of power. Could mean the difference between gaining a couple tenths of a db.
2008 - MECA Radical X2 World Champion 150.2
2009 - MECA Tennessee Radical X2 State Champion 153.2
2010 - MECA Radical X2 2nd Place 159.9
Shocker Sigs FTW!!!
Team Bangin' on a Budget
Old 12-07-2008, 12:15 AM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
i ended up with enough wire to do my big 3 X 2 lol. i may do 2 runs of power to the alt, and 1 run of ground from alt to bat
Old 12-07-2008, 12:20 AM
bwoodroof's Avatar
Brandon W.
0/11 sssss1648
it would help out a lot more than most people would think
Shocker Sigs FTW!!!
Sundown Amp question mytyeerinpie General Car Audio Discussion & Questions 23 11-16-2008 10:40 AM
question about batteries waresgaragestereo General Car Audio Discussion & Questions 8 11-05-2008 11:00 AM
RE box question tater Enclosure Discussion & Design Construction Help 10 11-03-2008 10:50 PM
