Is 6.4 cubes @ 40hz a good 18" box?? - Car Audio Classifieds!
Old 05-13-2010, 04:27 PM
Vaginatarian's Avatar
0/11 ssssss473
Default Is 6.4 cubes @ 40hz a good 18" box??
The only way I can get a design to work in this car, biggest I can go is 6.4 cubes BEFORE displacement, would be 100" exactly of port. Slot port
Would that sound good on an HDC3 18 on 2k ish??
Old 05-13-2010, 05:17 PM
0/11 ssssss337
Just off the top of my head that will leave you a little over 5 cubes net which is a little on the small side but will work still very good. Make your port 80 sq" in opening area and about 22" in length. This should tune you around 38hz
Old 05-13-2010, 05:22 PM
0/11 ssssss492
That.
You could up the power a little bit too.
References: Check my iTrader or just ask.
Ignorance is bliss. This post brought to you by someone who enjoys watered down, industry/radio tunes. I'm willing to share the lulz. Enjoy!
you think UGK is real? what the **** are you smoking? you are the kid still rockin fubu and shit arent you? Whats next G-unit?
Old 05-13-2010, 08:18 PM
0/11 ssssss462
I agree with j31rob do abt 80sq in on the port but I'd prolly do 24in or so to make sure u get low
94 s10 pickup
8 10in sa-10s
yellow top in the front
3 sprinters
270a mechman alterntor
soon to have 6 6.5 4xl and 2 8in xl
knukonceptz wiring
all equals abt 150db and rising
on music
refs: i have most on car audio forum: but here they are : PioneerSPL1990, Immociide, BumpinKota, twistedchild420, silentbass, joe 14, mbrooky
Old 05-13-2010, 08:25 PM
0/11 ssssss203
i am tuned to 38 with the 12" hdc3's and they get pretty dang low tuned that high you will just have to break them in to hit lower cause when mine were not broke in they did not hit the lower notes as good and i think mine are not fully broke in still.
Old 05-13-2010, 08:52 PM
0/11 ssssss462
Yea if thy aren't broke in take it easy on em for a while
94 s10 pickup
8 10in sa-10s
3 sprinters
knukonceptz wiring
on music
Old 05-14-2010, 12:33 AM
0/11 ssssss473
My box design internal volume is 6.47 cubes
after port/sub/little bracing displacement I get 4.8 cubes
This is with 100" of port.....
Should I build it??
Old 05-14-2010, 07:10 AM
0/11 ssssss337
Should I build it??
Too much port opening area. Reduce your port area to 80 sq" and you will gain a little net box volume which will help.
Old 05-14-2010, 10:46 AM
0/11 ssssss473
Dont you recommend 16" of port per cube?? 16 X 6.4 = 100 almost on the dot
Old 05-14-2010, 11:07 AM
0/11 sssss1013
but that is before displacement. once you are down to 5 or so cubes after you account for the port volume, your port area needs to shrink
16 * 5 = 80
10s thats will work good in 4 cubes and are cheap snoopysnooper General Car Audio Discussion & Questions 16 03-09-2010 01:09 AM
1 18", 4600wrms, 5 cubes, 36hz what would you pick? RetroAudioInc General Car Audio Discussion & Questions 42 01-19-2010 04:49 PM
Songs that play around 40hz Patrick Simmons General Car Audio Discussion & Questions 14 07-10-2009 04:19 PM
5 ft. @ 40hz DC Box NoPh33rRaCiNg Build Logs 19 07-01-2009 09:48 PM
[Relisting individually]FS: (2) 15" Eclipse Titaniums in a ~16 cubes designed by PWK! BlackWaterOp Car Audio Packages 12 06-15-2009 05:53 PM
