Does this seem right??? - Car Audio Classifieds!
Old 05-14-2010, 11:00 PM
0/11 sssssss25
Unhappy Does this seem right???
I just installed a high output 220 amp alt from DB Electric Yesterday and still have the stock battery. When I have the car running my multimeter says It's 16.3v - 16.4v and when I have it off It's at 14v.... I was wondering if this is harming the electrical in my car other than the system.
Also showing My first alternator swap and big 3 ( big 4 In my case)
Old 05-14-2010, 11:17 PM
luises14's Avatar
Loyal Member
0/11 sssss2531
Feedback Score: 30 reviews
multimeter is broken is my guess. regular battery can't hold that high of a charge
Old 05-14-2010, 11:35 PM
0/11 sssssss25
Ya its probably off like 2 volts...... so much for tryin to cheap out and buy a 10 dollar meter off of ebay instead of a fluke
Old 05-14-2010, 11:36 PM
AudioAnonymous's Avatar
0/11 sssss1723
if you have a new battery handy for your DMM try replacing it and see it if changes otherwise you can take your DMM apart and calibrate it sometimes (done that before)
CACTUS SOUNDS
2006 db drag WF 3rd place 161.2 SM3-4
2007 db drag WF 1st place 163.4 SM3-4
Loudest to date 165.9 SS3-4 with borrowed equipment
2010,2011 db Drag World Finals judge.
Old 05-14-2010, 11:40 PM
luises14's Avatar
Loyal Member
0/11 sssss2531
bought mine from walmart for 12 bucks its been pretty accurate. walmart FTW
Old 05-14-2010, 11:57 PM
sdelthon's Avatar
Active Member
0/11 ssssss619
why do you run a wire from the ALT->ACC (PWR disturbution thing) -> then to the battery?
1 MA Audio HK 4000d
2 MA Audio HK hk12x2
4 C&D Batts
and my trunk is falling off...
TEAM GORILLA
Team Lethal Beatz
Old 05-20-2010, 06:03 PM
0/11 sssssss25
I read that on these cars most ppl do it and have seen a couple of other pics with it done like that.... also that's where the stock wiring goes so I was just replacing it which is. Better for the electrical
