Adding second battery in trunk - Car Audio Classifieds!
Old 05-15-2010, 11:46 AM
KAPONE.SS's Avatar
0/11 ssssss484
Default Adding second battery in trunk
Ok I got this guy on the ImpalaSSforum and he is trying to tell me that running a Positive and negative from the front battery to back battery is a complete waste of money. And just to ground them in the back. I was hoping to get Nathan aswell as other Members to post here the correct way to run a Battery up front and a battery in the rear.
Rebuilding.......
Old 05-15-2010, 11:51 AM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
I asked this question not too long ago and a handful of people said to do a run of - from front to back. Some said a run from front to back and even grounding it as well.
I honestly laugh at half the audio talk on car forums. There were people on my nissan forums telling me that sound deadener doesn't help flexing and that I don't have a balanced system because I don't run 6x9s lol
Old 05-15-2010, 11:59 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
it depends LARGELY on the vehicle, and the capable conductance of the chassis.
some vehicles the chassis is a good enough conductor that a negative run is not needed.
for me to say, it really depends on your ENTIRE electrical setup and amps being used.
Old 05-15-2010, 12:14 PM
KAPONE.SS's Avatar
0/11 ssssss484
That is what I was trying to tell him, but he said he would never waste the money. I told him that if people pay the extra money it must make improvment. It is for a 94-96 impala ss. I know that as soon as I added negative runs in my Impala the electrical became more stable.
Rebuilding.......
Old 05-15-2010, 12:26 PM
Veteran Member
0/11 sssss3026
there you go, if it helped for you thats your answer.
fwiw i have 2 runs of 1/0 ground to the back. the more power you have under the hood the more wire you need to get to the back.
Old 05-15-2010, 05:01 PM
0/11 sssss1016
So true!! If there is weld close to the grounding point, then you are not going to get a good ground.
'1.888.497.7693 x1211
Old 05-15-2010, 05:03 PM
0/11 sssss1016
We recommend running from the front to the back. One way I look at is if you are going to spend the money on subs, amps, alt, batteries, and everything else. Is a few feet of wire from the front really going to kill you? Why limit your audio systems abilities over a few feet of wire?
Old 05-15-2010, 05:05 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
def add the run
92 Ranger Walkthrough
(Under Construction)
Old 05-15-2010, 06:00 PM
KAPONE.SS's Avatar
0/11 ssssss484
Thanks for the reply's hopefully the guy will take's the advice.
Rebuilding.......
Old 05-16-2010, 12:42 PM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
i thought the same thing its a waste. till i did run the ground from the front to the back in my jimmy.
world of dif with voltage stabilization of my electrical gained over a 1v were i was dipping below b4. so now i run if not 2 grounds from the front to the back at least one.
Adding second battery gbo559 General Car Audio Discussion & Questions 24 11-24-2009 10:41 PM
Adding 2nd alt, 2 more batts, best way to do it? CleanNMean General Car Audio Discussion & Questions 43 10-13-2009 02:39 PM
adding a battery. silvercookie General Car Audio Discussion & Questions 6 09-06-2009 10:32 PM
Adding another layer of mdf? pear_b Enclosure Discussion & Design Construction Help 0 08-31-2009 02:26 AM
Wanted : Tutorial on doing Big Three when battery is in trunk NOFATTYS Tutorials & Quick References 2 04-17-2009 09:17 AM
