quick ? answer asap.. - Car Audio Classifieds!
Old 05-15-2010, 12:17 PM
midnite toka's Avatar
0/11 sssssss61
Default quick ? answer asap..
ok im tryin to connect two cvxs 4ohms
i connected them + to + then out to the pos amp then n - to - then to the neg of aamp the rest two coils of each speaker together point is its supppose to be a 4 ohm finall load and its 2 ohms final load chech wit the multimeter wtf
" In front of my screens on 360 playin halo"..Z-ro
Old 05-15-2010, 12:19 PM
0/11 ssssss456
go to the12volt.com and they have a wiring diagram wizard. just follow that. double check everything.
Old 05-15-2010, 12:20 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
are they svc?
Old 05-15-2010, 12:21 PM
0/11 sssssss61
thats wat i did i followed there diagram and its commin out wit 2 ohms load which is wierd cause u cant make 4 ohms speakers in to 2 ohm load
Old 05-15-2010, 12:22 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
If they are SVC and both are 4 ohm then thats right. It should come out to a two ohm load.
Old 05-15-2010, 12:27 PM
0/11 ssssss489
^^^ this in parallel resistance is halved 4 and 4 is 2 2 and 2 is 1 and so on in series 4 and 4 is 8 and 2 and 2 is 4 and so on
kmanian1's Avatar
mine>yours
0/11 sssss2130
yep, I wonder if he has single 8ohm subs
Old 05-15-2010, 12:28 PM
branham1127's Avatar
0/11 sssss2108
Yep
Old 05-15-2010, 12:31 PM
0/11 sssss6030
He says they are four? but doesnt say if they are svc or dvc?
Old 05-15-2010, 12:35 PM
0/11 sssssss61
ok thanks !!! i "found" problem... well i fix it in oder words thanks
Any questions you just couldn't get an answer to.. I can help. iamsonic New Member Orientation 47 10-14-2017 11:54 AM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 07:41 PM
don't know if anyone's up to answer, but amp placement?? mcdstvn General Car Audio Discussion & Questions 39 08-22-2009 01:51 AM
I have a small problem, need a quick answer RE_XXX General Car Audio Discussion & Questions 11 05-12-2009 02:44 PM
