new box help - Car Audio Classifieds!
Old 05-17-2010, 12:48 AM
0/11 ssssss153
Default new box help
i plan on building a new box for 2 re sxx's 12's. i built one for a single sxx and the box is about 2.5ft cu with 37.5square inchs of port and the port length was around 26 or something i cant remember, tuned to around 35. now if i want to build a box for 2 of these is it as simple as just doubling everything up like making it 5ft cu. with 75 square inches of port and making the port length longer?
Old 05-17-2010, 02:41 PM
0/11 ssssss153
Old 05-17-2010, 05:27 PM
wahvtec's Avatar
0/11 ssssss226
yes port area and cubic footage double assuming your using one common chamber and the port will have to be recalculated. In other words those two factors double, but ur port length does not.
Old 05-17-2010, 05:31 PM
Jacobbz206's Avatar
0/11 ssssss258
Or make a dual chamber box with the same specs on each side..... thats an easy way also.
//Team NWSPL\\
CAN YOU DO THA DANCE?
Old 05-17-2010, 05:42 PM
0/11 ssssss153
na i want it one chamber. so basically double port area to 75 square inchs and leave my port length alone?
Old 05-17-2010, 05:57 PM
0/11 sssss1943
You will have to change your port length ato keep the same tuning.
Old 05-17-2010, 07:32 PM
Jacobbz206's Avatar
0/11 ssssss258
Use a port calculator, I can't drop links since I'm on my phone but i m sure you can google one, takes like 1 minute to find port length.
//Team NWSPL\\
Old 05-18-2010, 06:31 AM
wahvtec's Avatar
0/11 ssssss226
yes port has to be recalculated its not directly proportional like cubic footage and port area here is a simple calculator win isd works to and can be downloaded for free but this one seems to work for me.
PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
