Questions bout my amps. - Car Audio Classifieds!
Old 05-17-2010, 09:40 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default Questions bout my amps.
Ok i was playing my music today. Got home and just outta curiousity decided to check my voltage. Let the back seats down and started to check and noticed that my amp was warm. So i continued on to check my voltage. It was almost at 13 volts. So i check my other amp and it was warm too. So i dont know if there was something wrong with the amp to make it hot or if it was just that inside the trunk was warm?
Question number two. While i was Checking the voltage i checked the ohm loads of my speakers. My door speakers turned out to be 5 ohms a piece and i had never heard of a 5 ohm speaker. So i checked my 6x9's and they were 4 ohms a piece. My sub was 2.5 ohms. And i know its a 2 ohm sub. So i wonder if its my DMM or what? What do you guys think?
Old 05-17-2010, 09:41 PM
jbizzle's Avatar
0/11 sssss4346
Feedback Score: 26 reviews
Electronics create heat, and I'm assuming they have no ventilation being trapped in your truck.
Could just be the resistance of the DMM, nothing to worry about.
'07 Chevy Trailblazer SS AWD (Garage Queen)
- Alpine 9887
- Eclipse SC8365 3-Way front stage
- Sundown SAX-125.2
'98 Jeep Grand Cherokee (Daily)
- Alpine 9887 (Active)
- Selenium 6" Mids, 4 Crescendo CTS-1 Tweeters
- Sundown SAX-100.4D
- 2 Sundown SA-12s
- Sundown SAZ-1500Dv2
Team Sundown Audio
Old 05-17-2010, 09:42 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
1.) The amps will get a little warm, its normal
2.) Its Imp rise and did you disconnect them to check?
Old 05-17-2010, 09:43 PM
0/11 sssss6030
Whats Imp rise?
Old 05-17-2010, 09:45 PM
0/11 sssss6190
Whats Imp rise?
Impedance rise. It happens because of connections, and wiring and the like.
Old 05-17-2010, 09:48 PM
0/11 sssss6030
O ok So would independence rise cause one set of speakers to read one ohm higher and not make the other set rise?
Old 05-17-2010, 09:50 PM
0/11 sssss6190
Ever meter a subs coil and it will read 1.4 ohm each, then when wired in parallel in a box it will read 1ohm instead of .7? Same concept. Its just the resistance of all the other things in the chain.
Old 05-17-2010, 09:53 PM
0/11 sssss6030
O ok gotcha Thanks.
Old 05-17-2010, 09:54 PM
ltr450racer690's Avatar
0/11 sssss3414
very well put
A few questions about old school RF amps MisterTedster General Car Audio Discussion & Questions 6 03-10-2010 02:07 AM
Questions bout 4 15" Wall Josh Wahlie Enclosure Discussion & Design Construction Help 4 03-06-2010 02:39 PM
what do you think bout mb quart? kingmade08 General Car Audio Discussion & Questions 9 02-28-2010 01:03 PM
wtt ...2 mtx 7801 amps...563 209 8373 with questions 187 car audio Car Audio Trader (WTT) 6 02-22-2010 02:34 PM
How bout them Cowboy's!!!!!! twistedchild420 Sports and Fitness 30 01-09-2010 10:24 PM
