Change in Plans - Car Audio Classifieds!
Old 05-18-2010, 12:25 PM
0/11 ssssss208
Default Change in Plans
What do you guys think of this?
Vehicle: EK civic hatch
Originally, I was going with dual 15's 9cuft tuned to 32/33hz. Subs and ports up.
Now, since I still have the 3rd Q15, I decided to add it to the equation. I am designing a box to replace my back seat. It will have 3 15's firing forward. Two directly behind the head rests and one centered and slightly lower. The port will fire back towards the rear hatch. It will be 12cuft +/- after displacement tuned to 32/33hz. The top will be fiberglassed, so the 2 subs behind the head rests, behind the B-pillar, are elevated to the height of the head rests and there will be a dip in the middle so that I can see out my rear view mirror. (not sure if my description is good, but that's how it will look) The 3 subs are dual 1's and will all be run to the PAI-2000.1. I know the amp can handle .5ohms, so this should be fine. It is not geared towards total SPL. I just want a nice n nasty daily ground pounder.
Change of plans! Need a recone for a ver.1 sundown nightshade rachidfunaki (Fix My Speaker) 7 03-30-2010 12:50 AM
system plans fyerbyrd22 General Car Audio Discussion & Questions 58 01-04-2010 08:46 AM
Weekend plans? Patrick Simmons Off Topic Chat 81 11-07-2008 10:16 PM
