about power going to sub - Car Audio Classifieds!
Old 05-19-2010, 01:53 PM
0/11 ssssss153
Default about power going to sub
so say i have a sub where im running 4k rms in amps or a amp to the sub, its obv gooing to be too loud just for listening to daily full tilt all the time but does that mean if im running it like half volume that it will wreck the sub causing me to have to get it reconed n stuff? or as long as i have the amp/amps set correctly so it is getting 4k rms and i just have the bass turned down on my head unit it will be fine and not cause any damage?
Old 05-19-2010, 01:57 PM
0/11 ssssss775
Feedback Score: 17 reviews
At full tilt, you're using up more wattage. At lower volumes it sends less wattage. I dont get your question?
Old 05-19-2010, 01:59 PM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
he is askin if he underpowers his sub will it blow
NO is the answer
Old 05-19-2010, 02:01 PM
0/11 ssssss153
i was told that if u run the sub under its rated wattage that it can be bad for it. so wut im saying is if the sub is rated at 4k rms and i have 4k rms of amps going to it, is it fine to run with my bass turned down for daily? like if i have the amps set so there is 4k rms of power going to it but my bass is turned down? when i turn it down on the head unit does it reduce the watts going to the sub?
Old 05-19-2010, 02:03 PM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
i just answered your question man.
no it doesnt hurt the sub.
Old 05-19-2010, 02:10 PM
0/11 ssssss136
I dont think that will be a problem im running my RD hw 15" on only 1500 no problems with the sub.
2002 honda civic dx
Alpine CDA 9886
1 RD HW V2 D1 15"
New amp on the way
141.2 on tl sealed. making my up slowly
Old 05-19-2010, 02:27 PM
AuZy_AuDiO's Avatar
Air Pumpin' Terrorizer
0/11 sssss1114
You got a little confuzzed my dude. That means. Don't be putting like say a 200w amp on a 4k sub and Cranking it up because it can cause damage. Reason why we can put 1500w amps on like 2-3k subs is mainly cause we don't do 100% gain because it is just not good to do.
You can put a 2k amp or even a 1k amp on the sub if you want. Just don't make the amp go full power thus creating a weaker, sound, Clipping occurs because it decides to compensate and send signal instead of true power.
other then that, I am sure that is what he asked.
Source:Pioneer 80PRS|Front Stage| Eclipse SC8365 3-way components|front stage Amp:4ch Old school Alpine 350w|Substage: RE Audio XXX 15" DVC2| Sub Amp: Sundown [email protected] 1ohm|Box:Spy 3.5cubes @ 33hz
Old 05-19-2010, 02:30 PM
0/11 ssss31255
The reason people say too low of power kills speakers is because when you turn the gain or volume or bass boost up to "make up the difference" you are likely to exceed the capacity of the amplifier to produce the signal without reaching it's limits. Which means you go beyond clean signal into clipped signal which gives bursts of DC current which causes heat which causes failures of all kinds: coil, tinsel lead, spider {if a lead burns it}, connection failure, and possibly coil adhesive failure.{slinky}
With the amplifier and signal chain set up correctly, a subwoofer will not die from less power but some subwoofers barely move with 500watts so, that's no good either.
[SOLD]F/S - XS Power S925 w/ XS Power #527 GM Adapter SundownAudioNY Wiring, Electrical & Other Installation Equipment 10 04-23-2010 07:35 AM
Enough power??? Rd4me General Car Audio Discussion & Questions 4 01-30-2010 10:00 AM
Too much power? need2speed75 General Car Audio Discussion & Questions 5 09-03-2009 11:29 AM
without power still:( splvictim20 Uncensored Off Topic 22 06-28-2009 10:45 AM
How to become a CACO Power Seller in the Power Seller Program Patrick Simmons CarAudioClassifieds' Power Seller Program 152 10-20-2008 10:56 AM
