whatcha think? Memphis 8 sub install - Car Audio Classifieds!
Old 05-19-2010, 08:14 PM
0/11 ssssss149
Default whatcha think? Memphis 8 sub install
So I am installing a very small setup in my friends 05 gmc crew cab. We are installing 2 MS84D Memphis subs. 8" dual 4 ohms. Going under the rear seat. Amp is a sundown 125.2
The Box size will be .3 cubes sealed without woofer. (2 seperate boxes)
Should I downfire?
I am thinking downfire wired in series/parallel to get 4 ohm load. that would be 400Watts to the both of them.
Old 05-19-2010, 08:28 PM
0/11 ssssss531
ID say subs up man
Old 05-19-2010, 10:05 PM
0/11 sssssss65
i've had the best results firing the subs down in those trucks. Kinda small boxes considering how much space is under the seat. You wouldn't need to go much bigger and then you could port those too.Then it will be impressive!
8's are always cool because it always do way more than expected
Old 05-19-2010, 10:50 PM
0/11 ssssss149
For what it is going to be sealed is fine for him. Just want to add a lil low end for him. So that is 2 for down fire and 1 for up so far.
Old 05-26-2010, 10:21 PM
0/11 ssssss149
So I built one box and did a temp install to see if I like and I don't. Thinking of ported now. Both in one box 1.8 cube tuned to 35hz. Whatcha think.
install help Whitymanne General Car Audio Discussion & Questions 5 05-15-2010 05:11 PM
Need some help with my new install Scruffy_Nerfherder General Car Audio Discussion & Questions 1 04-01-2010 08:09 PM
Memphis MCH1300 aka Memphis Big Belle SPY Multi-channel Amplifiers 23 02-01-2010 06:42 AM
$60 in PP, whatcha got? k3n12ock Wanting to Buy (WTB) 10 01-28-2010 06:40 PM
Upcoming completion of my build whatcha guys think? nismos14 General Car Audio Discussion & Questions 8 09-09-2008 01:45 PM
