whining noise - Car Audio Classifieds!
Old 05-19-2010, 10:42 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default whining noise
I have this whining noise comming from my door speakers when i accelerate. What could cause this? It started when i put my system in and i have a stock alt.
Old 05-19-2010, 10:44 PM
Kyle K's Avatar
Wangin' Out
0/11 sssss1812
Feedback Score: 32 reviews
are you sure its not your alt?
I have a TL pm if you want to get metered.
working on the new build...
who knows what itll be
Team CACO
Team Wangin' Out
Old 05-19-2010, 10:46 PM
0/11 ssssss567
ground loop. check your grounds
http://www.caraudio.com/forum/wiring...-take-two.html
08' VW GTI BMP
Old 05-19-2010, 10:47 PM
0/11 sssss6030
I cant tell you for sure that its not, but it sure does sound like its comming from the speakers.
Old 05-20-2010, 12:46 AM
0/11 ssssss775
Feedback Score: 17 reviews
Dude, it's from your alternator. Redo the grounds to your amp. If that doesn't fix the problem, it may be the alternator itself. I had unstoppable alternator noise, until I realized it was going bad. When I replaced it the whine went away.
Old 05-20-2010, 12:49 AM
Ryan1126's Avatar
0/11 sssss9178
Check your grounds, scrape away all of the paint under it (if there is any) also, i could be from having your rca's run along side of your power wire. If this is the case then re-route your rca's down the other side of the car.
Old 05-20-2010, 08:43 AM
0/11 sssssss14
I had this problem in my Dakota. It's a ground loop. You should check your grounds.
Old 05-20-2010, 10:53 AM
0/11 sssss6030
All my grounds are good.
Old 05-20-2010, 11:10 AM
Ryan1126's Avatar
0/11 sssss9178
are your rca's running along side of your power cable?
Old 05-20-2010, 11:11 AM
0/11 sssss6030
Nope the power wires dont run to the front so there nowhere near each other.
check out this cry baby whining about loud stereos. More spl General Car Audio Discussion & Questions 18 05-16-2010 01:06 PM
Amp Noise mythyone General Car Audio Discussion & Questions 0 04-21-2010 09:29 PM
Whining Noise when A/C is on? gbo559 General Car Audio Discussion & Questions 2 10-26-2009 07:05 PM
Whining engine noise!! westman995 General Car Audio Discussion & Questions 14 10-10-2009 05:30 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
