vr4000d protection issues? need repair? - Car Audio Classifieds!
Old 05-20-2010, 07:46 PM
0/11 sssss1642
Default vr4000d protection issues? need repair?
Well I have had the amp for over 2 years and never one problem with it. Well I was tunin my 4 channels and notice the vr goin in and out of protection. So I restart the car and it still does it. I have not had a sub hooked up to it for awhile, as I was just finishing up my 18" box for this weekend.
What caused this? The amp was only on with no sub hooked up, so it was only being powered on
anyways, I need it fixed, advice? jbizzle was sayin its cuz I had no subs hooked up for a long period of time with the amp still powering on. So whats wrong with it?
Old 05-20-2010, 08:25 PM
Prohibited Sellers/Buyers
0/11 sssss1770
check the ground it will do that
Old 05-20-2010, 08:32 PM
0/11 sssss1642
yeah I hadn't gotten to that. Everything is locked nutted on buss bars so I assumed they were fine. But I hope it is that simple
Old 05-20-2010, 08:42 PM
0/11 sssss1770
i say take a look inside and see if anything is loose
Old 05-20-2010, 08:50 PM
Loyal Member
0/11 sssss1129
Not having subs hooked up on a live amp is not going to kill the amplifier someone is smoking the crack pipe, something else happened do the normal spot checks.
2012 West Coast INAC Amateur SQ 1st place Champion!
2012 National 2nd place INAC Amateur SQ Champion!
Old 05-20-2010, 08:58 PM
0/11 sssss1770
yeah i fix amps man and i never heard that ive used amps that have been un uesd for years that not it.
Old 05-20-2010, 09:13 PM
0/11 ssssss203
yea it will not go bad from no subs hooked up cause no power was going out of the amp to be able to clip or anything.
Old 05-20-2010, 10:35 PM
Loyal Member
0/11 sssss1129
There is power coming out of the amp even with no load on it, me thinks something hit the speaker out terms or a bad ground or remote wire issue.
Old 05-21-2010, 04:16 PM
0/11 sssss1642
well im taking out the amp and will open it up. Talked with roger at crossfire and he said he could help me, but they are the only one's that can pretty much repair them. Hope its a simple fix cuz it is hard as hell to find boards for them
Old 05-21-2010, 04:23 PM
korn4life's Avatar
0/11 sssss3718
Feedback Score: 25 reviews
Unless the board is burnt through or something major you shouldnt need a new board. Im sure if something did go bad it can be fixed.
Amp protection? SpeakerBox General Car Audio Discussion & Questions 3 02-15-2010 05:33 PM
protection davidt487 (db-r) 1 11-04-2009 11:41 AM
Ground and Amp Protection nicker10 General Car Audio Discussion & Questions 4 09-29-2009 05:00 PM
Amp into protection mode.. nismos14 (Sundown Audio) 7 08-22-2009 05:04 PM
D3 400.4 goes into protection newarkbeast973 Broken & Non-working equipment 2 05-29-2009 12:08 PM
