Advice on system plans - Car Audio Classifieds!
Old 05-20-2010, 07:54 PM
0/11 ssssss143
Question Advice on system plans
Hey guys I just joined this after reading through it today seems like a cool site!
Anyways curently I have two setups 2 kicker cvr 15'S dual 2ohm hooked up to an alpine mrp m-1000 and I also have a jl w7 12 that I am currently using with the same amp. The kickers are just in my room for now
Well I was looking at getting 2 aq sdc 15's and run them with a sundown 1200.1d would this all be a louder setup that either of my current systems? Any advice guys?
Old 05-20-2010, 08:29 PM
98AckCL23's Avatar
0/11 sssss9929
1st off, welcome to CACO.
2nd, to answer your question, it's completely install dependent. For example, the 12 W7 could be your loudest setup, if the install is wrong for both of the dual 15 setups. That being said, assuming good installs for all of them, yes, the AQ's should be louder. Just be sure to either build your own box to AQ specs or have someone build it to AQ's specs. The correct box makes a huge difference in the output/sound of your subs.
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 05-20-2010, 08:32 PM
0/11 sssss8594
Feedback Score: 55 reviews
x2
Enclosures
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
like he said, its all in the box, and i would look more towards a 1500 watt amp. something like a sundown saz-1500d. a saz-1500d on to aq's in the correct size box will blow away either one of the two setups you mentioned.
Old 05-20-2010, 08:33 PM
Ryan1126's Avatar
0/11 sssss9178
also port/sub placement is key along with the correct tuning of your amp and enclosure.
Old 05-20-2010, 08:41 PM
0/11 ssssss143
quick replies! well i emailed AQ and told them i had a box for 2 15's already 3.2 cubic ft per chamber tuned at 32 hz. they said it would be perfect. so assuming that it is perfect i would be a lot louder than my jl w7 in the built to spec box?
also i read somewhere that the sundown 1200.1d amp pushes out about 1500 rms i could be wrong though.
one more thing the 2 sdc's allow me to wire them down to one ohms right?
Tags
aq sdc, jl w7, kicker, m1000
need advice for my audio system. celicagtman General Car Audio Discussion & Questions 12 04-23-2010 09:12 PM
New system build advice!!! Help please!! kingz0Vbass General Car Audio Discussion & Questions 7 03-28-2010 10:00 PM
system advice mads10bass General Car Audio Discussion & Questions 15 02-08-2010 05:45 PM
system plans fyerbyrd22 General Car Audio Discussion & Questions 58 01-04-2010 08:46 AM
Need some advice on finishing my system chinesemonkey91 General Car Audio Discussion & Questions 6 04-03-2009 04:04 PM
