Problem with system plz help - Car Audio Classifieds!
Old 05-21-2010, 03:10 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
Default Problem with system plz help
Well I did a install 98 jeep cherokee. Pioneer 6500, audiopipe ap10001d 3 sundown e8's. Well first off one of them got the tinsel burned up, im only sending 200 watts to each(gains set with dmm). When the volume is turned up higher the subs keep cutting in and out rapidly but when u cut it back down a few notches it stops, I tried my saz1500d on it also and it does the same thing. So it's gotta be the cd player right,or maybe the rca's they are stinger ones but very old.? It's wired at 1.34 ohms both amps are 1 ohm stable and beyond. I also tried with a set of subs 3 cheap off brand svc 4 ohm 10's . And they still we're cutting out and popping.
1999 Durango 2 Memphis Mojo 15's Audiopipe ap3k
4 Date Safe 75 ah batts Alpine hu. Lots of wangin
Old 05-21-2010, 03:14 PM
0/11 ssss31255
Check all your tinsel leads. another may be broken on the inside of the lead itself causing it to make and break connection during heavy movement. This would cause spikes in resistance and would shut the amp down.
just a thought.
Old 05-21-2010, 03:21 PM
Prohibited Sellers/Buyers
0/11 sssss1770
sounds like the amp if there isnt damage to the subs or could be a short maybe
Old 05-21-2010, 03:26 PM
Loyal Member
0/11 sssss1129
A DMM is not a failsafe way to avoid amp clipping its a good and easy alternitive to not having an O-Scope.
Also not sure how the hell you guy's burn up the leads on these E8's I have had my 4 running 350+ rms each since late 08 never once had an issue like that.
Take the subs out and hook a DMM to check ohm rating then free air them with 20hz-10hz to get the cone moving on low volume to see if they cut out from bad leads.
if they read fine and dont cut out on free air then start checking other things.
2012 West Coast INAC Amateur SQ 1st place Champion!
2012 National 2nd place INAC Amateur SQ Champion!
Old 05-21-2010, 07:07 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
The leads r fine. Like I said I checked 2 different setups 2 different amps. It's not the amps or subs. I know this. SO u guys think cd player or rcas? I had the amp turned at half gains and I know it's not clipping. So maybe the cd player is faulty or maybe te rca's are faulty. Im gonna put in some rockford hx2's next. He just tore up one e8 the other 2 r fine. And im sendin the other to get reconed.
Old 05-21-2010, 08:10 PM
0/11 ssssss532
Since you've already tried different subs and amp the next thing I would try would be new rca's
Old 05-21-2010, 08:53 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
Yea. I hope it's not the cd player. Gonna swap some new stinger rca's tomorrow.
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
system problem Fosgate1 General Car Audio Discussion & Questions 0 03-27-2010 01:50 PM
sub problem RidnClean General Car Audio Discussion & Questions 11 02-15-2010 07:44 PM
Amp problem CTIPPINS General Car Audio Discussion & Questions 2 10-10-2009 10:39 PM
Need Some Help with this problem. RE_XXX General Car Audio Discussion & Questions 11 06-01-2009 08:07 PM
