so i hooked up my new amp and....... - Car Audio Classifieds!
Old 05-21-2010, 10:57 PM
notloudenuff's Avatar
0/11 ssssss573
Default so i hooked up my new amp and.......
i hooked up the aq2200 i just got from someone on here and im not sure what the problem is or if there is even a problem.. the thing with it is that it seems to have barely any power pushing my fi btl untill i turn the gain on amp all the way up and xover all the way up. my memphis mc100d pushed it better on the same setup (rca's and speaker and audio control line driver)
was i just expecting too much or is there a problem anyone can think of?
it also has a constant vibration sound through the sub like a bad ground but all my grounds are done right and when i wiggle the rca's on the amp input i get a bad noise through the sub.
any help or thoughts would be great.
if you need more info just ask.
Old 05-21-2010, 11:03 PM
Jh8909's Avatar
NJ Car Audio
0/11 sssss3219
Feedback Score: 38 reviews
is the sub moving without any signal being sent to it from the headunit? if so does it look like its kind of bobbing up and down like its floating on water?
and when you wiggle the rca's can you describe what kind of noise you here through the sub? and did you change out the rca's and find out if that was the problem yet so you can rule them out?
Pics too big in sig.. Please resize
Old 05-21-2010, 11:06 PM
0/11 ssssss573
the sound is on when i pause the ipod or cd. when i wiggle the rca's it makes a high pitched "squeeling" noise, i guess thats the best way to describe it. i ran out of time to try a diff set of rca's but i will try to tomorrow.
the sub doesnt move much but you can hear it and feel it if u touch the sub
Old 05-21-2010, 11:07 PM
0/11 ssss31256
This is kindof my go to answer;
I think your RCAs are not grounding.
With the RCAs plugged into the amplifier take a 18ga or so wire and connect the wire to your ground and then touch the outside metal ring of the RCA with the other end of the wire while you have the stereo playing at 1/3 the total volume on the deck.
if it gets louder when you touch the wire to the outside ring you will know there is an issue with the signal. {either at the deck or at the amp}
another way to test it is to grab an ipod and a headphone to RCA converter and use that instead of the deck.
Old 05-21-2010, 11:09 PM
0/11 ssssss573
With the RCAs plugged into the amplifier take a 18ga or so wire and connect the wire to your ground and then touch the outside metal ring of the RCA while you have the stereo playing at 1/3 the total volume on the deck.
ill have to try that... im not really sure if its the rca's or not though cause my other amp played fine with them.
Jh8909's Avatar
NJ Car Audio
0/11 sssss3219
yes it is definatly an rca issue. and if its not external but internal on the amp then that new amp you got is bad homie. only way to find out is to do all the external tests on it you can to see if that solves the problem first.
Old 05-21-2010, 11:10 PM
0/11 ssss31256
Sounds like a solder connection within the amplifier.
Old 05-21-2010, 11:13 PM
0/11 ssssss573
if it means anything it seams the rca jacks on the amp move quite a bit not sure if thats with all aq amps or if that is an indication that they are loose inside
Jh8909's Avatar
NJ Car Audio
0/11 sssss3219
thats what I was thinking. have an old rf power 800.2 that has bad connections internally
Old 05-21-2010, 11:21 PM
Jh8909's Avatar
NJ Car Audio
0/11 sssss3219
shouldn't have anything to do with it, but I wouldn't suggest keep screwing with them. I would pop the amp open and look for lose/shorted connections. gonna have to have a patient eye though
hooked Drewculous General Car Audio Discussion & Questions 5 02-01-2010 12:46 PM
why doesnt my amp work unless hooked up in master to another in slave numba1system General Car Audio Discussion & Questions 2 01-07-2010 01:01 AM
hooked up everything amp won't turn on gbo559 General Car Audio Discussion & Questions 32 11-20-2009 11:43 PM
Hooked up a kid's system today,then cops show up! lol twistedchild420 Car Audio Videos 22 09-30-2009 12:18 PM
How to: Making sure your speakers arent blown/ hooked up backwards SPL Guru Tutorials & Quick References 1 08-04-2008 10:54 PM
