need help wiring them in the box - Car Audio Classifieds!
Old 05-22-2010, 01:22 PM
0/11 ssssss271
Default need help wiring them in the box
Hey i just got my 2 12' aq sdc subs today and i already have a box that SPY made me.
I am wondering how to wire the 4 wires on each of the subs..
Old 05-22-2010, 01:33 PM
0/11 ssss31258
What amplifier are you powering them with?
Are they dual 4ohm?
Old 05-22-2010, 01:42 PM
0/11 ssssss271
i will be powering them with a AQ1200D
and i think all SDC 12's are 4ohm
It has a set of white and red wire on each side of the sub.
just looked at site says D4 im assuming that mean 4 ohm
Old 05-22-2010, 01:56 PM
CLNFREAK's Avatar
0/11 sssss1788
Feedback Score: 23 reviews
the AQ1200d is 1 ohm stable (1ohm 1200 watts),
the subs are :
1200 peak music
600 continous power
so you will be just at the limit of the subs (IMO) at 1ohm.
you can do em at 4 ohm.
MAY 8 2009 ask me about that day !!!!
SUBS (2) 12" DC LVL 5
SUB AMP 1100.1
MIDS AND HIGHS AMPS 2 EXL 400.4
BATTS NSB group 31, XS power d3400
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
SINGERALTERNATORS.COM
Old 05-22-2010, 01:58 PM
0/11 ssss31258
the whites get connected together
the reds get connected together
do this with each sub;
Old 05-22-2010, 02:07 PM
0/11 ssssss271
wait the 1200d amp will power these correct? There site says this will power a pair of sdc 12's good.
Also, what happens when my box only has 2 plug things on each side?
Old 05-22-2010, 02:16 PM
0/11 ssss31258
yes your amp will power them. take the two positive{red} leads of each speaker and connect it to the positive {red} terminal of your terminal cup. Do the same with the negative {white} leads. then use 12gauge or thicker wire from the terminal cup to the amplifier.
Old 05-22-2010, 02:23 PM
0/11 ssssss271
Thanks, so a good way is to twist both red wires together? and both white?
Old 05-22-2010, 02:31 PM
0/11 ssssss271
this is in the box, do i connect the 2 white and reds to them but how do i connect them because i cannot put them in the little whole its to small...
Old 05-22-2010, 02:56 PM
StreetGlow's Avatar
0/11 ssssss683
solder/quick connect terminal
DC
Sundown
1/0 wiring forceww Wiring, Electrical & Other Installation Equipment 4 07-17-2009 01:01 PM
wiring help gjnelson General Car Audio Discussion & Questions 10 04-27-2009 06:07 PM
Sub Wiring ??? Blackout General Car Audio Discussion & Questions 18 01-30-2009 06:59 PM
Sub Wiring Help dkhage1 General Car Audio Discussion & Questions 4 01-19-2009 09:22 PM
TV With All Wiring Blackout Car Audio Trader (WTT) 6 12-24-2008 01:02 AM
