grounds - Car Audio Classifieds!
Old 05-25-2010, 10:00 AM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
Default grounds
i think i need new grounds in my trunk. but i need a place for 3 grounds. what would be an easy fix/solution to this instead of grounding to three different points in my trunk?
Old 05-25-2010, 10:09 AM
0/11 ssss31258
Find an easy to access area and remove the paint and such. Then drill a hole and bolt you leads to it.
or
You could use a grounding foot and distribution block.
Old 05-25-2010, 10:14 AM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
what is a grounding foot? how does it work
is there a certain kind of distro i need?
Old 05-25-2010, 10:20 AM
0/11 ssss31258
this is a grounding foot. [you still need to bare the metal it attaches too]
http://www.hifisoundconnection.com/S...id/0/SFV/30046
As far as the distribution block, it depends on the size of wire you plan to run.
Old 05-25-2010, 10:24 AM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
i have 1/0 for my amp and battery, and 4 gauge for my 4 channel.
Old 05-25-2010, 10:28 AM
0/11 ssss31258
Battery? what battery? [this changes things]
make the ground connection and run that to the battery. [ground foot or drilled and bolted or whatever]
then make your amplifier ground connections direct to the battery ground terminal.
Old 05-25-2010, 10:31 AM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
i have a d3100 in the back. check my build log. you can get a visual.
i already had a ground in there from a previous install that i ran to the battery.
i had to make 2 new grounds for the amp and 4 channel.
so are you saying that i can just run my grounds to the battery neg terminal that is grounded to the frame?
Old 05-25-2010, 10:34 AM
0/11 sssss1258
si senora
Old 05-25-2010, 10:40 AM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
well dam.
i was going to do that but my boy said i HAD to ground the amp to the frame.
that woulda saved me some time. i guess ill just rewire later on this week
thanks yall
o and JB you are a bish. lol
Old 05-25-2010, 10:43 AM
0/11 ssss31258
That's not nice but it is funny.
Speaker whine/hum & grounds? k3n12ock General Car Audio Discussion & Questions 3 03-19-2010 11:17 AM
Grounds? crownvicon26's General Car Audio Discussion & Questions 14 02-08-2010 11:19 PM
Stripping paint for grounds blfuller123 Tutorials & Quick References 4 10-30-2009 02:07 PM
