Connecting Batts - Car Audio Classifieds!
Old 12-15-2008, 08:18 PM
0/11 ssssss480
Default Connecting Batts
I'm gonna have two runs of 0 gauge from front batt to back batts, i'm gonna have 2 batts in the rear, wondering how should this be wired i know how tha fuse work goes, but is it connect front batt+, to rear batt1+, then from batt1+ to rear batt2+ ? and as far as the negative wire do i ground each batt and amp to it's own ground or could they all share one grounding spot, and since i'm using two runs of 0 gauge to tha first rear batt, do it also need to have 2 ground wires? help
Old 12-15-2008, 08:20 PM
DLP customs
Guest
0/0 sssssssss
Wire them in a series.
Old 12-15-2008, 08:21 PM
DLP customs
Guest
0/0 sssssssss
Ground all seperate if you can. To avoid ground loops.
Old 12-15-2008, 08:22 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
you got it right.
wire front batt + to back batt #1 + to batt #2+
same as ground, but run 1 ground to frame(could be wrong here)
so front - to back - to back - then another to ground.
wire both runs to the same batt terminal.
92 Ranger Walkthrough
(Under Construction)
RidnClean's Avatar
Ballin
0/11 ssss17858
i'm slow, and with errors
Old 12-15-2008, 08:31 PM
0/11 ssssss480
explain plz
Old 12-15-2008, 09:05 PM
DLP customs
Guest
0/0 sssssssss
Originally Posted by crownvic02 View Post
explain plz
pos to pos, neg to neg
Old 12-15-2008, 09:10 PM
no thats wiring them in parallel which is the right way
if you wire it in series it will put out 24 volts
series is batt one's + wired to alt then batt ones's - wired to batt 2's + then batt 2's - to ground
Old 12-15-2008, 09:13 PM
DLP customs
Guest
0/0 sssssssss
Ouch brain fart. No more posting while doing pricing. I deserve the ban parag.
Old 12-15-2008, 09:18 PM
I figured you just got them mixed up but I wanted to make sure he didn't look up a series wiring diagram on google
2v cell Hawker batts Make 16v w/ ur 12v batt Slam Wiring, Electrical & Other Installation Equipment 3 01-06-2010 07:00 PM
[FOUND] WTB batts mytyeerinpie Wanting to Buy (WTB) 26 01-22-2009 02:33 PM
DD Z motor for Batts djman37 Car Audio Trader (WTT) 3 09-15-2008 12:57 PM
Deep Cycle battS KOVEMASTER559 Wiring, Electrical & Other Installation Equipment 0 08-17-2008 07:09 PM
