How to check voice coils with dmm? - Car Audio Classifieds!
Old 06-16-2010, 12:38 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default How to check voice coils with dmm?
i want to sell my SE but i want to make sure that both voice coils read where they should, first what should they normally read at (d4)? and what setting do i set my dmm on, this is one of the many things i want to learn how to do.
Old 06-16-2010, 12:39 PM
0/11 ssssss857
what brand dmm do you have to start?
Old 06-16-2010, 12:41 PM
Ryan1126's Avatar
0/11 sssss9178
protek
i figured i set it to the ohm symbol (i dont know how to make the sign)
Old 06-16-2010, 12:43 PM
0/11 ssssss857
normally there is a resistance dial with the ohm symbol and thats the dial it needs to be on.
Old 06-16-2010, 12:46 PM
Ryan1126's Avatar
0/11 sssss9178
so i was right? right now it is fluttering between 3.0 and 3.4 is that good?
Old 06-16-2010, 12:53 PM
0/11 ssssss857
did you test both coils separate? Are they both reading right about the same? It sounds about right, guessing they are 4ohm?
Old 06-16-2010, 12:55 PM
AudioAnonymous's Avatar
0/11 sssss1723
I usually touch the DMM leads together to check the resistance of the DMM leads itself then check the voice coils. Then I subtract the DMM resistance from the VC resistance.
CACTUS SOUNDS
2006 db drag WF 3rd place 161.2 SM3-4
2007 db drag WF 1st place 163.4 SM3-4
Loudest to date 165.9 SS3-4 with borrowed equipment
2010,2011 db Drag World Finals judge.
Old 06-16-2010, 01:00 PM
Ryan1126's Avatar
0/11 sssss9178
yes its a d4, and they both read at 3.3 most of the time, they fluttered a bit.
Old 06-16-2010, 01:02 PM
0/11 ssssss857
yes they will flutter, and 3.3 on a d4 is about right. They are good.
Old 06-16-2010, 01:19 PM
Ryan1126's Avatar
0/11 sssss9178
thanks man
FS - 3" Voice Coils bwoodroof Speaker Accessories & Parts 8 09-10-2011 08:37 AM
Voice coils dont read the same 90talontsi General Car Audio Discussion & Questions 2 04-29-2010 12:01 PM
dual voice coils kmall002 General Car Audio Discussion & Questions 2 03-24-2010 03:44 PM
[SOLD] 15 Inch FI Q D1 Voice Coils Silenkiller 15" Subwoofers 5 03-14-2010 09:02 PM
Aluminium or Copper Voice Coils. Mojo General Car Audio Discussion & Questions 10 09-06-2009 02:30 AM
