wat size battery - Car Audio Classifieds!
Old 06-16-2010, 07:45 PM
heyshawty445's Avatar
0/11 ssssss236
Default wat size battery
i have a sundown 1500 at 1 ohm and a 4 channel hooked up to a run of 4 gage and a run of 1/0 gage
i have a stock alt and the stock battery in the front is the same
wat size battery should i get im getting voltage drops to about 12v when full tilt
should i just get a new batt in the front or one in the rear?
518SPL
Old 06-16-2010, 08:15 PM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
the biggest you can fit up front...
Originally Posted by Anthony VerticalScope
I personally don't give a shit what avatar you use.
and MiX and fatpat are valuable members of society? i dont thinks so. lol
i expect nothing less from a worthless piece of shit like yourself.
Old 06-16-2010, 08:18 PM
0/11 sssss3344
a big one in the front and rear xs power ftw
sundown nutthugger
so dont hate!
refs ssackett spy resko cruzin22z 1loudyukonxl bumpinbuick theemichealhughes ss audio 2loud4youmorris atsaubry crxbumpin pshcyoacoustics big c yukon crescendoaudio skatinbassplaya keifersracing getlow galaticmonkey getlikeme bass14 twisted turdfurgueson2 enemyofsilence taylorpro duran anton miller kowboy willie3719 kickerassman
TEAM SUNDOWN
TEAM EVO
TEAM INCRIMINATOR
TEAM BETTER LUCK NEXT YEAR
TEAM WHATS A WALL
Old 06-16-2010, 08:22 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
d3100 will fix your problems....for now. Noone stops at a 1500w amp lol. ^^^like he said, XS all the fvckin way
Old 06-16-2010, 10:28 PM
98AckCL23's Avatar
0/11 sssss9929
As mentioned, start in the front with the biggest XS Power you can fit. They have a very handy wattage scale in their section of the forum. Go by that, and then decide whether or not you'll need one in the back. Most likely, you won't. I know I don't really need one in back with my 1500D and 4 channel, and I was running a D5100R and my good ol' 80A alt...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 06-16-2010, 10:35 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Correction on my wrong statement...If you amp has like 100 amp total fuses then you will need about a 100 Ah supply...Probly not, because at kinetik they say they design their wattage ratings with what you need...There 50 something Ah battery is labeled a "1400Watt(or similar)" battery...But you could probly use this for a 1400watt system because the Amp-rate changes all the time...Someone correct me if i'm wrong...
Old 06-16-2010, 11:12 PM
0/11 ssssss236
thanks
518SPL
Old 06-17-2010, 05:16 AM
98AckCL23's Avatar
0/11 sssss9929
Originally Posted by Huricain3 View Post
perhaps a "1200 watt" battery atleast....depends..
You can actually get away with a lowish amperageHour-rating battery if you don't listen to music that much. For instance if you need like 140 amps for your sundown then you can play the sundown for an hour(actually more because the amp dosnt use the whole 140, it changes ALOT obviously)with a 140Ah rated battery
The Ah rating is the number of amps a battery outputs over a time of 20 hours, not 1 hour... So a 140 ah battery would be able to withstand a draw of 7A of current over those 20 hours.
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 06-17-2010, 02:20 PM
Novicaine's Avatar
0/11 sssss6135
Mybad....
battery size Bob Saget General Car Audio Discussion & Questions 2 04-19-2010 09:43 PM
What size kinetik battery? Mr_Northstar_816 General Car Audio Discussion & Questions 15 02-24-2010 04:06 PM
What Size Battery? cmwilson General Car Audio Discussion & Questions 11 02-16-2010 09:11 AM
What size alt will i need??? pcchris General Car Audio Discussion & Questions 5 12-24-2009 02:58 AM
What size battery do I need to run?? bran_luciano General Car Audio Discussion & Questions 5 12-17-2009 05:38 AM
