amp keeps overheating? - Car Audio Classifieds!
Old 06-16-2010, 11:38 PM
snoopysnooper's Avatar
Awaiting Confirmation
0/11 sssss4665
Feedback Score: 33 reviews
Default amp keeps overheating?
ok, so i have a visonik v800hc, it keeps overheating. in the manual it says "1ohm stable" but later it says not to wire below 2 ohms. so is it1 or 2 ohm? its all rated at 1 for the specs
well it keep overheating, no voltage drops, so my question is, what can i do to keep it from overheating? just find a d.7 or d1sub and shut up?
2006 grand caravan
sony dsx-s210x
lanzar opti 2k
3 sundown sa8v2d4
t-line unloading at 34
juice box black cherry
Old 06-16-2010, 11:41 PM
0/11 sssss1560
First I'll get the dumb questions outta the way for ya Is it mounted in a place with good airflow is it flat on the ground side ways all that stuff.
Loyal Member
0/11 sssss2152
Feedback Score: 35 reviews
It's probably safe to assume that amp is only 2 ohm capable. If you've got a dual 2 sub wire it for 4 ohms and then turn the gain up to 3/4 and see if it over heats it probably won't.
I'm just gonna ask my landlord to hold the car up while I take the tires off. I mean, she's old and all but should be okay.
Old 06-16-2010, 11:49 PM
0/11 sssss1560
Is this the amp where you have to remove the protection circuit to run it at 1ohm? Are you sure its not going into protect because of that?
Old 06-17-2010, 10:18 AM
heyshawty445's Avatar
0/11 ssssss236
go back to sundown like u always doo
518SPL
Old 06-17-2010, 10:24 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Fans. Lots of fans.
The moar fans you put on it the moar cooler it will run. You might even try routing one of your A/C ducts to blow on it.
Team CACO Team SHOK
Supporting Member
Old 06-17-2010, 11:42 AM
0/11 sssss1943
What, and only get 75% power?
Old 06-17-2010, 12:01 PM
Loyal Member
0/11 sssss2152
Or he could go 100% power and clip the shit out of his sub. That was just to test that it's an ohm load problem.
How do you have it wired? Are you sure you bridged it correctly because it's only 1 ohm stable when bridged in mono. I'm not sure about it but make sure it's in lp mode and try pulling one of the rcas to make sure it's getting a mono signal. I don't know how the visoniks work since i never had one but having both rcas could give it a stereo signal no matter what the sub's putting on it.
Also some amps that are supposed to be a certain ohm load stable are only stable above that. Check your sub to make sure it's giving a 1.1 or higher final ohm load it might be pulling a lower load than you think.
Old 06-17-2010, 01:41 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I believe that one is 1 ohm "stereo" stable 2 ohm mono. What kind of electrical and what gain settings do you have it at?
Old 06-17-2010, 01:44 PM
Old skool junkie's Avatar
DTD
0/11 ssssss712
Feedback Score: 22 reviews
Its 0.5 ohm stereo, and 1 ohm mono. Being that it's class A/B though, it's destined to get hot; but not so hot it shuts off.
Any voltage drops?
SQL?? One or the other folks, make up your mind already!
Don: Surfer, you are a really well known SPL box builder - how do you make a box sound REALLY loud?
Surfer: You taketh the cardboard paper towel roll, you cutteth said roll longways, you tapeth said cardboard to the boxeth.
Computer Overheating Puppy Linux Help! its_ray_ray Technology & Computer 0 02-15-2010 12:32 PM
amp overheating!!!! spennycivicsi02 General Car Audio Discussion & Questions 31 08-10-2009 03:18 PM
HELP. trucks messing up/overheating...BAD canyouhearmatt Off Topic Chat 40 12-18-2008 04:06 PM
