300 amp alt rebuild - Car Audio Classifieds!
Old 06-17-2010, 01:07 AM
Awaiting Confirmation
0/11 ssssss152
Default 300 amp alt rebuild
i bought a 300 amp alt for a 07 dodge ram from iraggi about a year ago, i installed it but i know that it has never put out 300. i have a 01 dodge ram with a 5.9, iraggi said that the alt is the same and it will work. i had it put on a load tester and it failed miserably. i dont know whats wrong with it and i have never got iraggi to answer me back about it. i just want it to work. what will it take to fix it/ rebuild it?
Old 06-18-2010, 03:27 PM
resko1's Avatar
<<< atomic at7000.1d
0/11 sssss2134
Feedback Score: 21 reviews
Man Mechman is the bomb! I hooked him up with one of my stock alts and he did an amazing job. Said it dyno'ed just over 300a and never dropped below 240 at 300 degrees. all from a stock unit!
Hes a pretty busy guy but builds some amazing alts!
just an old fart
Old 06-18-2010, 04:04 PM
0/11 ssssss576
how much was it to rebuild your stock alt?
bought from: hc3_cuz, iamsonic, RJRD2, zeuslicious
sold to: treylittlefield,DonH,bambino9584,mbdblue
Old 06-20-2010, 08:47 AM
resko1's Avatar
0/11 sssss2134
I aquired a promotional deal through Matt, so normally its about 500-600. These units are virtually indestructable and usually produce at least the rated amperage.
just an old fart
Old 06-20-2010, 09:09 AM
0/11 sssssss78
Old 06-21-2010, 04:21 PM
MECHMAN's Avatar
0/11 sssss1142
You are welcome to send it in. I will dyno test it for free, and e-mail you the exact output curve. I cannot guarantee that I can improve on it, but there is a chance that I could get some better performance, or possibly get you into an altogether better unit.
Old 06-21-2010, 09:14 PM
0/11 ssssss152
alright cool, what do they typically run for that car? something around 250 would be plenty for me i think. i think 300 was more than i would have needed anyways, but i dont think its even getting 100 to be honest.
what address do i send it to?
Old 06-22-2010, 09:13 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Were did you have it tested at? I have ran my Iraggi 300 for almost 4 years now with no problems....once you get over 260a idle output is sacrificed somewhat.
Old 06-23-2010, 09:02 AM
MECHMAN's Avatar
0/11 sssss1142
Our units range in price for $375 to $599 depending on output and options. Lets take a look at the unit on the dyno first, it might actually put out 300 amps, and the problem could be somewhere else.
dd rebuild ? bigchili (PSI Car Audio) 1 06-13-2010 05:19 PM
Help Me Rebuild PLZ murderedtahoe General Car Audio Discussion & Questions 10 04-05-2010 01:41 PM
crx rebuild audiobuffru12 Build Logs 24 02-15-2010 07:38 PM
My PC rebuild madmat Miscellaneous Build Logs 61 01-21-2010 02:06 AM
Want to do a rebuild... Andrew Enclosure Discussion & Design Construction Help 22 05-16-2009 10:42 PM
