could hifonics brutus be dropped to .5 ohms safely - Car Audio Classifieds!
Old 06-18-2010, 08:48 PM
Captain Tying Knots
0/11 sssss1220
Default could hifonics brutus be dropped to .5 ohms safely
im just wondering. if i could have the electrical to keep it above 13 volts would it work
Old 06-18-2010, 10:56 PM
0/11 sssss1435
It might hold up if its only for burps. i wouldnt run it daily that low tho
I would like my signature back please ant. I don't appreciate it being changed.
Old 06-18-2010, 11:04 PM
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
No, if it was meant to run at .5, it would be rated for it. Make sense?
Old 06-18-2010, 11:11 PM
memphis87's Avatar
0/11 ssssss171
My buddy is running his bxi2610d at .5ohm no problem. And i don't agree with the previous post. Just because they rate it at 1ohm doesn't mean its not .5 ohm stable. Im sure manufactures say 1ohm so it persuades people from wiring the subs down.....but since impedence is always changing they'll have to make an amp that is stable at impedences that dip below the amps "stated" stablity.Granted that that music is dynamic and the impedance of your subs is always changing. With rise, you'll be fine @ .5ohm....now if your were using a 2ohm stable amp and running it at 1ohm then that's a different story since there is such a large drop in the impedance
2 18" AQ HDC4's
1 crescendo bc5500 @1ohm
1 Crescendo Concerto 1100.4
6 crescendo pwx's and 4 vifa 1" tweets
Official DB drag score 151db @ 38hz
youtube: hulbert87
Old 06-18-2010, 11:13 PM
0/11 sssss1435
a lot of quality amps are only rated and warrantied down to 1 ohm because they dont want people running them for hours on end that low because they will get hot. but my amp, the sundown saz1500 is only rated for 1 ohm. but will drop down to about .25
DD, sundown, RD, atomic, ect. ect arn't rated for .5 but they will
op you could try it chances are the rise of your box is putting you over .5 anyway
Old 06-18-2010, 11:36 PM
mads10bass's Avatar
NOT LOUDER THAN YOU :(
0/11 sssss7335
Feedback Score: 36 reviews
A buddy of mine had his 2006 on a dc lvl 4 with 5 coils at .5 daily no problem. It got warm but was fine.
WOW
Old 06-18-2010, 11:48 PM
Mr.Green's Avatar
0/11 ssssss333
What about a church 3000d pro at .75 Daily?
Old 06-18-2010, 11:51 PM
0/11 sssssss48
you can run it at .5 for burps but i wouldnt reccommend it for a daily driver
Old 08-09-2010, 12:23 AM
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
My buddy blah blah blah..........................and he never mentioned or even knows what his final load is, he asked about .5ohms.
I agree, but we are talking about Maxxonics Bxi line. They will NOT run @ .5 continuous. I can say this from PERSONAL experience, not "my buddy's"
I agree, but we are talking about Maxxonics Bxi line. They will NOT run @ .5 continuous. And once again, he asked about .5ohms, never mentioned or probably even knows what his rise is.
Yep, but if you are buying The Bxi line, you probably are not into serious comp and are just looking for a budget daily amp. Sorry if i'm coming off as an azz, but i am giving the OP an answer based on experience, not
speculation.
hifonics brutus bestaudio Mono Amplifiers 6 12-28-2010 01:37 PM
Hifonics Brutus BXi-2006d Ricoshay Mono Amplifiers 9 02-17-2010 05:52 PM
Hifonics brutus bx1500d speedkilz420 Broken & Non-working equipment 1 10-18-2009 06:19 PM
Wtb hifonics brutus speedkilz420 Wanting to Buy (WTB) 0 10-18-2009 06:01 PM
used hifonics brutus bxi1606d PrezCar Mono Amplifiers 4 08-06-2008 01:51 PM
