Sludge - Car Audio Classifieds!
Old 06-19-2010, 07:30 AM
0/11 sssssss38
Default Sludge
Does adding the activator to the spectrum make it any strong or better then just spraying it on with the sprayer? I understand you can apply it thick but is there any more benefit to it? I already have the activator but im debating if it is going to be easy to spray it or apply it as a paste.
Old 06-19-2010, 09:16 AM
J&T DESIGNS's Avatar
0/11 ssssss791
You can not spray Spectrum Sludge. The activator is only there to change the viscosity, so what that means is the more activator you add the thicker it will get. If your looking for a spray form you would need (Spectrum).
db Revolution
J&T DESIGNS
Old 06-19-2010, 09:27 AM
0/11 sssssss38
yes i understand this. spectrum is spectrum then you add activator to make it sludge. spray spectrum vs spread sludge. is one more "deadening" then the other?
Old 06-19-2010, 10:31 AM
JWPOORE's Avatar
Brand New Members
0/11 ssssssss3
I think they are the same. The only difference is that the "sludge" version allows you to apply a thick single coat to achieve ideal results. Spraying Spectrum would require several thin coats to build to the same thickness. Both I believe will achieve equal results but from what I have seen on pictures online, spraying Spectrum looks nicer and doing Sludge is a quicker one step alternative.
Old 06-19-2010, 11:51 AM
old CACO Admin's Avatar
CEO Status = Inactive
0/11 sssss3054
Correct..
Once cured there is absolutely no difference between the two products.
In fact, Spectrum already has activator in it to begin with.
Without it, the Spectrum would have the viscosity closer to water...
ANT
Old 06-19-2010, 12:10 PM
0/11 sssssss38
ok. yea i was debating buying the sprayer! Applying sludge on my roof with a spreader just screams mess to me! lol Im gunna mask,plastic, and spray.... sounds like best way to do roof
SPL Sludge slamnride (Second Skin) 42 03-25-2010 04:33 PM
SPL Sludge almost ready !! old CACO Admin (Second Skin) 54 09-21-2009 07:11 AM
