Are the voice coils on my sub damaged? - Car Audio Classifieds!
Old 06-19-2010, 11:26 AM
0/11 sssssss25
Default Are the voice coils on my sub damaged?
I recently purchased a used sub from a member of this forum. I need to know if my readings are within limits or not. The sub in question is an image dynamics idmax 10d2v2. it has dual 2 ohm voice coils. I checked the readings on 3 meters. I'm only getting 1.3ohms on each voice coil and about 2.5 when theyare wired up in series. Now i have ohmed out my 18 year old 15s which have single 8ohms and they read about 7.8 ohms and my 4 ohm mids read about 3.8 ohms so these 2 ohms that should read closer to maybe 1.9 or 1.8 ohms wouldnt you think? Please tell me if my reading are within tolernace or I have definate damage. I can only do 4ohm mono bridge on my amp and I'm thinking if I put a 2.5 ohm load on it I might cook it.
Old 06-19-2010, 11:31 AM
ascitiesburn69's Avatar
0/11 sssss1645
If they were damaged they typically don't read less than "rated" impedence. Be more like 40ohms or something. The coils are fine. Most companies use coils slightly under the rated impedence to combat impedence rise a bit. For instance I had a DC level 3 12" dual 4 and it read 2.8ohms each coil.......
Team S.P.E.A.D.
Trunks FTW
Old 06-19-2010, 11:40 AM
0/11 sssssss38
Same for my dc xl
Old 06-19-2010, 11:43 AM
0/11 sssssss25
ok guys thanks. so one more thing. my amp im gonna run on this sub is a ppi art series a600.2 which can do 600 x 1 @ 4ohm mono bridge. Am I safe putting this sub on it at 2.6 ohms?
Old 06-19-2010, 12:10 PM
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
There will be an impedance rise. You will probably be actually running the amp over 4 ohms. I think your amp should be fine.
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
Old 06-19-2010, 12:13 PM
0/11 sssss1645
Chances are it wont BLOW the amp, the power light will flash or turn a different color when presented too low of an impedence IIRC. Try it out and if it doesn't stay playing then just wire a coil to each channel, should be around same power anyways.
Team S.P.E.A.D.
Trunks FTW
Old 06-19-2010, 12:21 PM
0/11 sssssss25
ya ok. i got it hooked up. no low impedence light. thanks for all your help everyone
FS - 3" Voice Coils bwoodroof Speaker Accessories & Parts 8 09-10-2011 08:37 AM
How to check voice coils with dmm? Ryan1126 General Car Audio Discussion & Questions 9 06-16-2010 01:19 PM
Voice coils dont read the same 90talontsi General Car Audio Discussion & Questions 2 04-29-2010 12:01 PM
dual voice coils kmall002 General Car Audio Discussion & Questions 2 03-24-2010 03:44 PM
[SOLD] 15 Inch FI Q D1 Voice Coils Silenkiller 15" Subwoofers 5 03-14-2010 09:02 PM
