Engine whine only when plug in sub's RCA..? - Car Audio Classifieds!
Old 06-19-2010, 06:06 PM
jprix82's Avatar
0/11 ssssss150
Default Engine whine only when plug in sub's RCA..?
Pioneer HU, Got a 4 ch amp running comps on 1+2 ch and 2 12's bridged on 3+4 ch,with 2 sets of rcas.
I get engine noise when I plug the rca going to ch 3&4.
I switched the rca from 1&2 with 3&4 to see if rcas was the culprit but still had noise from ch 3&4.
Old 06-19-2010, 06:07 PM
Super Moderators
0/11 sssss9623
ground ur rcas
Old 06-19-2010, 06:11 PM
0/11 sssss1435
pioneers are notorious for that. either replace the pico fuse or ground the rcas to the cage of the HU
I would like my signature back please ant. I don't appreciate it being changed.
Old 06-19-2010, 06:44 PM
jprix82's Avatar
0/11 ssssss150
Forgot to mention that, I have the rca's grounded.
Old 06-19-2010, 07:24 PM
0/11 ssssss440
But did you replace / fix the pico fuse.?
Old 06-19-2010, 07:26 PM
0/11 sssss1435
if it was the pico fuse gounding the rcas would fix that i believe. did you check grounds for HU and amps?
Old 06-19-2010, 07:31 PM
jprix82's Avatar
0/11 ssssss150
not yet.
Yes, I just dont understand why i only get noise on ch 3 &4,which is the subs. I can hear the whine through my comps.?
Old 06-19-2010, 07:34 PM
0/11 ssssss364
do you have any signal processors in line before the amps?
Colorado's Usaci state record holder
SPL
Streat beat
Old 06-19-2010, 07:54 PM
jprix82's Avatar
0/11 ssssss150
no sir
Old 06-19-2010, 07:55 PM
0/11 ssssss513
are you using a 4channel by any chance? i have a pioneer and i had supe rbad ground noise i grounded the rcas, and it was still there so i had to ground teh rca'son the amp too. to completely make it go away
box w/ port plug Kyle K Enclosure Discussion & Design Construction Help 13 05-17-2010 12:39 AM
What is the plug on an alternator for? FatBoy2 General Car Audio Discussion & Questions 20 11-22-2009 12:38 PM
After lots of troubleshooting still engine whine in a 1999 Civic Tempe General Car Audio Discussion & Questions 9 06-02-2009 12:27 AM
[BASIC] Engine whine and Ground Loop Fixes danteBirosel Tutorials & Quick References 0 11-12-2008 02:05 PM
[BASIC] Engine whine and ground loop fixes danteBirosel Tutorials & Quick References 0 11-12-2008 01:38 PM
