ok the new Soundigital Van i got problems need help - Car Audio Classifieds!
Old 06-19-2010, 06:47 PM
0/11 sssssss88
Default ok the new Soundigital Van i got problems need help
ok here it is , i am having problems with subs coming apart! its the top and bottom on the pass side. i went thru 3 subs in 2 days 2 of them were the bottom pass. and what failed is the cone ripped off the coil this happend doing a legal #. the 3rd one is the foam surround riped about 1/4 way around on the top pass. side top sub, on far pass. side of the sub close to the edge this happend doing a outlaw #. i have rd hw subs reconed by psi. these subs have 4 spyders. can anyone tell me what else i can do!?!?!?!. i guess ill put it out there, after i put 4 new subs in last night i did a single burp just to check them out and i did a 166.3 legal. i was ok with that and didnt want to push it yet and to save them for a big show next week and went to a small show today.i didnt realize after that burp test last night i had ripped the cone off the coil i just packed up and loaded up. just had to add that so ya know what kind of pressure we are dealing with.
167.2 Legal
168.7in the kick
NSPL Current World Record Holder
TNESPL Current World Record Holder & Loudest Legal Score Recorded
Team Soudigital
Old 06-19-2010, 06:52 PM
AudioAnonymous's Avatar
0/11 sssss1723
Might be your baffle is too thick and the back pressure you're putting on the sub is alot greater then all the others. I know alot of louder SS vehicle have that same problem.
CACTUS SOUNDS
2006 db drag WF 3rd place 161.2 SM3-4
2007 db drag WF 1st place 163.4 SM3-4
Loudest to date 165.9 SS3-4 with borrowed equipment
2010,2011 db Drag World Finals judge.
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Losing pressure somewhere, and subs unloading most likely.
Seal up that pass door good if its not already.
Youtube VIDz :
Old 06-19-2010, 07:21 PM
muriloalvares's Avatar
0/11 sssss1252
Gary,
Subs will have to be made for your car, reinforced where they are breaking.
Old 06-19-2010, 07:24 PM
0/11 sssssss88
im think that murilo you are right but where can u get and who should i use asap lol
167.2 Legal
168.7in the kick
Team Soudigital
Old 06-19-2010, 07:25 PM
0/11 sssss7816
you could always try one of the spider hold down rings
Atomic Loudspeakers
Audiotechnix
Old 06-19-2010, 07:44 PM
J&T DESIGNS's Avatar
0/11 ssssss791
I would try epoxy on and around the spiders first and see if it would hold up. For your surround issue I have found that gorilla glue works great. If the epoxy doesn't work try different spider configurations like 3 stiffs, 2 med,and 1 or 2 soft. Are you using a horn design enclosure? I would have to agree with unloading, but I don't think your problem is back pressure, I mean if it was I think you would fold the cone before you tore a spider with that kind of power.
db Revolution
J&T DESIGNS
0/11 ssssss791
double post
db Revolution
J&T DESIGNS
Old 06-19-2010, 08:33 PM
0/11 sssssss88
what seams to be happing is where the cone is glues to the coil it rips off the spyder is fine on the outside edges and for most part still intack with the coil. what take the gorila glue (wood type) and coat the underside of the foam with one layer?
167.2 Legal
168.7in the kick
Team Soudigital
Old 06-19-2010, 08:43 PM
0/11 ssssss791
We do both sides of the surround, it wont look pretty but it works. your subs are failing at the triple joint. Your subs are moving to far and it is ripping at that point. You could try and epoxy the triple joint but I have never tried that so I don't know what would happen.
db Revolution
J&T DESIGNS
WTB Soundigital 12k or 16k amp loud avalanche Wanting to Buy (WTB) 1 04-04-2010 06:28 PM
SounDigital at SBN muriloalvares General Car Audio Discussion & Questions 46 03-09-2010 04:50 PM
WTB: Soundigital 8k, 12k loudernu Wanting to Buy (WTB) 2 01-31-2010 02:03 PM
soundigital 8k psychoacoustics Mono Amplifiers 26 01-06-2010 06:05 AM
looking for a possible SounDigital amp statonburrell General Car Audio Discussion & Questions 0 08-19-2009 01:59 PM
