question on AQ1200D power - Car Audio Classifieds!
Old 06-20-2010, 09:33 PM
la2lvtom's Avatar
0/11 sssssss24
Default question on AQ1200D power
I am currently running 16 10's being powered by 4 Kicker XS100's (1200 each at 1ohm) 1 of the amps is cutting in and out and I have a feeling it is gonna cost a pretty penny to fix (12 year old A/B amps) so I am thinking of running maybe 4 AQ1200D's, my question is if I decide to do this will my 3 Kinetik HC2400's at the amps and 1 HC1400 under the hood be enough to supply the amps (the alt is an Ohio Generator 186 amp at 2000 rpm) just trying to figure out the overall price of changing. Thanx in advance
Old 06-20-2010, 09:43 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Yes and why not just get (2) AQ 2200's? Would be much cheaper.
Old 06-20-2010, 09:46 PM
Prohibited Sellers/Buyers
0/11 ssssss481
if they are supporting the kickers the aq 1200s should be fine.
Old 06-20-2010, 10:01 PM
indytrucks's Avatar
CACO Late Night Crew
0/11 sssss5387
x2
Old 06-20-2010, 10:08 PM
la2lvtom's Avatar
0/11 sssssss24
My subs are dual 2ohm which I have connected in series to 4ohm each then I have each amp running 4 subs at 1ohm each so to run 2 AQ2200D's I would have to run the amps at either 2ohm and get no power or run them at .5ohm which I really am not a fan of running amps that low. Anyway I would get more power out of the 4 AQ1200D's (about 5500 watts) as opposed to 4400 out of the 2 AQ2200D's.
AQ1200D amp wiring kit kprobst1001 General Car Audio Discussion & Questions 3 06-15-2010 09:00 AM
Power wiring question TheJesus General Car Audio Discussion & Questions 9 02-26-2010 09:11 AM
aq1200d at .5 ohm? SUBW123 General Car Audio Discussion & Questions 8 02-07-2010 08:39 PM
WTB: AQ1200d ArcFault Wanting to Buy (WTB) 6 01-04-2010 04:11 PM
OZ power series question Jacobbz206 Enclosure Discussion & Design Construction Help 6 12-20-2009 10:50 PM
