burning smell - Car Audio Classifieds!
Old 06-21-2010, 11:15 AM
jorgesau100's Avatar
160+ DD ftw
0/11 ssssss424
Default burning smell
it is going to be my birth day on the 6/22 so my wife and my brother got me sum subwoofers
i built a subwoofer box that holds 4 15 PA mofo x d2
specs: box 11.5 ftcube tuned to 34hz port in the center
the amp i am useing right now is a PA crypt 5500
i am planing on geting 3 more of those amps so i can have one for each subwoofer
but hears the problem i have them in and they still play and sound good but if i crank up the bass for more than 1 song smoke starts to come out the port this only happens when i turn up the bass
the amp all so went in to protect mode once i let it cool down and for 20 mins then turnd it back on and it was as if nothing ever happend it still sounds nice
i want to know why is my subwoofer giving out smoke
thanks for the help
Old 06-21-2010, 11:22 AM
sound_around's Avatar
0/11 sssss9691
Impedance is wrong (final load) ,playing way below tuning.....IDK just guessing
Old 06-21-2010, 11:23 AM
0/11 ssssss852
but hears the problem of have them in and they still play and sound good but if i crank up the bass for more than 1 song smoke starts to come out the port this only happens when i turn up the bass
thanks for the help
are the subs making any type of funny sound now after the smoke came out of the enclosure?
Sounds like u could have maybe fried a voice coil.
[SIGPIC][/SIGPIC]
140.9db @37hz w 2 10" on 1500w
AQ Nuthugger
car audio is the new drug bro!!! F*ck with this and you go broke!!
wat they dont know is that real ballers run AQ
wait wats AQ?
JL's mean stepdad
Old 06-21-2010, 11:27 AM
fiBl18's Avatar
0/11 ssssss368
since ther d2 did you wire in parallel and series so you have a final 1 ohm load? i would check with a dmm
sundown sa-8 build in progress
Old 06-21-2010, 11:50 AM
160+ DD ftw
0/11 ssssss424
i wired them parallel and series so i could get a ohm load of 1
i put the port in the center would that mess up with the tuning since i put 2 subs on the left and 2 on the right
Old 06-21-2010, 11:53 AM
160+ DD ftw
0/11 ssssss424
i am going to put a vid up on youtube right now so i will add a link
the subs do not make any wierd sound it just smells funny
160+ DD ftw
0/11 ssssss424
the subs get hot and the amp gets hot too
Old 06-21-2010, 11:56 AM
160+ DD ftw
0/11 ssssss424
Old 06-21-2010, 11:57 AM
160+ DD ftw
0/11 ssssss424
160+ DD ftw
0/11 ssssss424
why does the blade keep burning my mdf wood.? kickerfanatic General Car Audio Discussion & Questions 33 05-29-2010 03:58 PM
Sub problems. Burning coil? armymp90099 General Car Audio Discussion & Questions 6 04-17-2010 10:52 AM
That new car Smell!! BigC-Expo General Automotive Chat 27 01-09-2010 06:48 PM
